Updating Swing radio software
Dear all,
I have a problem with crackling audio when using apple carplay. The car is a 2019 Fabia SE with a Swing radio.
I understand that the software version 8755 (currently 8742) can solve this problem.
Does anyone know if this can be done at home rather than having to visit the dealer?
Skoda update portal says there is no available update...
Thank you.
  • Replies 408
  • Views 103.8k
  • Yes the update file can be sent to you
  • None 😞
  • Maybe my post do not complies with forum rules and I am so sorry if I'm doing something wrong, but this situation is really serious and against the warranty law: Skoda refuses to fix it, asks for mo
I have update file for this, but you can only attempt to make the update... it will either work or not.
Thank you. Is the file available to download?
Let me check PC again, and send you link in a few minutes.
On 25/7/2022 at 8:32 ΜΜ, varooom said:
Επιτρέψτε μου να ελέγξω ξανά τον υπολογιστή και να σας στείλω το
Hello, I need a help pls.
I would like to update the software of bolero to my fabia 1.4tdi style because the MirrorLink is not working properly... Moreover, I saw the date of the last update of the software it was about 2013... Now we are 2022...
Please give a help about it....
You will need to post a picture of your Software Train, hold down Menu button and then you will enter the hidden menu.
You must be able to enter this to be able to perform update.
8 hours ago, MariosFABIA said:
Version 0138 is available, and I will send you private message in a few minutes
Hello, can someone help me to get the update (8755) for my infotainment system?
You shall have PM in next 5 minutes or less
Do you still have the file mate?
I have them all, but you need to narrow down the search.
Hold down menu key a few seconds to enter hidden menu.
Post back your Software Train details.
Give me 10 minutes to double check software train compatibility.
No problem.
Is the service menu the only "hidden menu" on the swing there is??
And where do I find the quadlock diagram of det mib2 gp? I have every repair manual there is, and I really can't find the wires I'm looking for. Found for my speakers. 4x 2way components but I can't find "switch on/radio on/ignition" wire anywhere.
Maybe more, but I have not entered it.
Wiring diagrams depend on what your car has specification as to what is wired up.  Should you take a picture of your quadlock and each connector wiring, then it can be decoded in time.
Maybe there's an update for that?
@pab567 I don't have this, is this in your collection?
Unfortunately not 😞
Thanx for the fast reply!
Is there any sources available where from search to?
If me and Pab567 cannot find it, you will struggle.
Not all things have updates sadly.
Understood! Thanx anyways! Maybe I should get newer radio.. there is one available for 20€
That's entirely your choice, might be best left alone if it all works.
Goodluck whichever you decide.
Hello
can you svare This update file sorg me aswell?
thanks in advance
37 minutes ago, Heggedalen said:
Hello
can you svare This update file for me aswell?
thanks in advance
Can you please find your Software Train value from your car, usually hold down your Menu button and then find it.
This is also location you will need to perform the update.
