VCDS needed
Hi all, looking for someone with VCDS closeby. I am visiting family and my superb has come.up with a light bend fault I understand @micloi may be closeby to Warwick / Leamington?
Edited by AmanT
Tagging not done properly
@micloi AmanT is asking for help with VCDS.
You may wish to edit your car to add a year it was made to assist, as some new cars need a more modern cable to talk to the car.
Best of luck.
Thanks @varooom for your help. Car is 2010 superb 2
At a guess, either water ingress to the underside of the headlight or a damaged level sensor :)
It'll probably just mean the headlight drop to a 'safe' mode to avoid glare to other drivers. If you minimise night time driving, you'll probably be OK until you get home.
@langers2k thanks, will VCDS confirm which of these issues is responsible?
I don't want to jinx it but yes, I would expect the fault codes to give a good indication of where the issue is :)
