workshop manual
i am looking for a paper manual for a 2012 superb 2.0tdi  as i will be doing a timing belt change on mine soon . is one available ? if not how good are the haynes electronic ones ?
erWin Skoda, you can download the PDF files, which you can then print off page(s) as needed.
Price of 2 beers, not too bad really (get VIN to hand)
I’d give a dealer a ring for a price.
when mine needed done it was about £380 for parts from Tps
£460 from dealer
wasn’t worth the hassle me doing it but that was four years ago
£460 from dealer
i would rather do it then i know whats been done . its not a bad one to do i have done worse . the manual is just useful for torque settings ect . i have got a dayco kit with water pump and all the idlers for £106 so not too bad .
Make sure you have the lockdown tools too or you will have problems.
i have ordered a set
I’ll probably end up doing mine by myself next time also.
Only thing am not sure about is the cam and injection pump bolts if you have to replace them. Sure it’s torque then angle.
would use the old ones 1st till I knew the timing was right then swap one by one
which timing/locking set you ordered ?
Edited by Snapper1725
just a cheap e bay one  in the past i have had a few of them they work ok
If you're not sure, replace them. They're not that expensive compared to the cost of the repair if they fail.
i gave in and paid for the Haynes autofix online manual . it looks nice and easy to use clear pictures and diagrams . got it for £20 with the discount code . about to go and do a cambelt and water pump .
2 hours ago, landroverbodger said:
I gave in and paid for the Haynes autofix online manual.  It looks nice and easy to use clear pictures and diagrams.  Got it for £20 with the discount code.  About to go and do a cambelt and water pump.
erWin Skoda is 7 Euro for the download PDF's, but if you have the information now, then all is good.
this one i have online for as long as i need it . it can be seen on any device i am using with a password . it was probably my computer skills that messed the erWin up for me . the timing belt change was all going ok until i discovered the new tensioner was faulty now waiting for a replacement to arrive .
