Replacement radio/satnav/infotainment suggestions for a dead Amundsen pleas
I’ve killed my wife’s radio. Ā Touchscreen failed and I found a replacement on eBay but neglected to check in advance how bl**dy difficult it is to replace just the digitiser rather than the whole screen unit. Ā Screen got wrecked in the process.
Ā
Cheapest repair option (given that replacement screens seem to be unobtainable) would seem to be an after market double DIN system.
Ā
What I don’t know is whether we’ll lose the visual indication of obstructions when reversing and use of the steering wheel controls. Ā My wife has an iPhone so I’m guessing a pure Android head unit won’t talk to her phone (which we would like it to do).
Ā
Ultimately I’m looking for the nearest ā€œlike for likeā€ replacement that will retain as much of the original functionality as possible without costing an arm and a leg.
Ā
Any suggestions?
And can anyone tell me how to edit the subject line? šŸ˜‰
Report your own post, and there will be option to add some manual text, an admin will come along and edit post.
I think because this is your 2nd post, you will not be able to edit things just yet.
I'd buy an RCD330 or RCD360 as a replacement
You could try calling Ant on 07979723977.
He's in West Midlands and does a repair service on Amundsen2 units and last I read, he had Amundsen2 screens.
Ā
He has had v.good reviews here and on YOC.
Kenwood DMX8020DABS has wireless CarPlay and Android Auto. There is a Double Din fitting kit that contains a cable to connect to steering wheel controls. Not sure the parking sensors work with this unit.
Ā
Unit cost - £650  - It is a mechless unit, meaning NO CD PLAYER!
Fitting kit - £136 - was £99 just last week!
Ā
If you're not bothered about wireless Carplay and Android Auto, you could go for the 8019DABS model, possibly around £100 less, but finding them, now that Kenwood have released the 8020, is another matter!
Ā
If you really need something for rear parking, you could look at getting a lowline or highline rear camera, but the fitting would be a long process, and labour charge would be in the region of £200-250.
Ā
I've had a labour cost for infotainment replacement quoted to me at £150, but I think it's easy enough to do yourself, as you've already probably taken the trim off, and unscrewed the broken unit out.
Ā
My first port of call in your situation would be to call Ant, as mentioned in another reply. He is highly recommended on the Amundsen repair work.
I want also to change to Xtrons.Ā
