Bilstein B4 or Racingline Performance Dampers?
Hey all,
I am getting a knocking noise from my steering/suspension on my mk3 Octy VRS estate. Only happens turning right with a 90 degree turn of the wheel when it's slightly loaded up.
I'm suspecting topmounts or ARB links. Ultimately if I'm paying to get the topmounts changed it may make sense to  change the dampers, springs and ARB links to refresh the suspension whilst I'm at it.
I've had Bilstein B4's and Eibach springs on other cars which were ace. I'm struggling to find B4's for the Octy online though but have seen front and rear Racingline Performance Dampers for £493 and wondered if anyone had experience?
Also, any recommendations for online retailers who can supply Bilstein B4's?
Thanks in advance,
Doug
It's best to find what build codes your shock absorbers have. Do your front shock absorbers have 50mm or 55mm struts. If they are 55mm (shown as 54.6mm below) then they are probably in the list below.
8 5Q0413031EQ Gas shock absorber 54,6MM 2 PR-G02
8 5Q0413031FP Gas shock absorber 54,6MM 2 PR-G03,2UC
https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/753/4/411/411001
25.05.2015>>
8   5Q0413031ER Gas shock absorber 54,6MM 2PR-G02,7IM,7ZV
https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/753/4/411/411005
25.05.2015>>
8 5Q0413031EP Gas shock absorber 54,6MM 2 PR-G04
8 5Q0413031EQ Gas shock absorber 54,6MM 2 PR-G05
8 5Q0413031ER Gas shock absorber 54,6MM 2 PR-G06
8 5Q0413031FP Gas shock absorber 54,6MM 2 PR-G07,G08
8 5Q0413031FS Gas shock absorber 54,6MM 2 PR-G10
https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/753/4/411/411006
KYB 3358015 front shock absorbers are sold to replace all of the above OEM part numbers.
https://www.autodoc.co.uk/kyb/14359022
Sachs 315 911 and Sachs 317 330 front shock absorbers are also sold to replace all of the above OEM part numbers.
https://www.autodoc.co.uk/car-parts/shock-absorber-10221/skoda/octavia/octavia-combi-5e5/59680-2-0-tsi-rs?supplier[0]=32&criteria[100][1]=VA
Edited by Carlston
  • Sponsor
Drop us a PM with your registration number if you're still looking and we can check what is available for your model.
Damian @ DPM Performance
25.05.2015>>
25.05.2015>>
Thanks buddy, I don't want to go Sachs ideally. As a VRS I am pretty sure I have 55mm struts but I'll check.
Or koni special actives. They are bloody good. Had them on octy, deisel 4x4 suoerb and now my 272
I've had a look and seem to be getting conflicting information as to whether they fit the VRS. From research it needs to be 55mm struts and multi-link rear suspension but the Koni website states it doesn't fit the VRS. However they do a set which are 55mm front and for multi-link rear which also fit the MK7 Golf GTi, effectively the same platform.
