Fuel Gauge
Iv just filled the tank up from almost empty and something strange happened..
after driving about 5 miles the needle has dropped to 3/4 full and the range has gone down. I can’t see any leaks and the cap hasn’t fallen off 😆.
Any idea what might have happened?
  • Sponsor
Check whether or not your outside temperature readout is giving a sensible number, that and the fuel gauge sender share a voltage feed.
Temperature seems about right
Someone must have had a similar problem?
Anyone
Replace the fuel tank sender if it bothers you.
  • Sponsor
Another possibility is a cracked solder joint on the connector from the instrument cluster circuit board.
Try giving the whole area a bit of a shake by hitting with your palm on top of the dashboard, see if the reading on the fuel gauge changes.
