Leaking into passenger footwell.. potential door problem
Hello everyone, first post on Briskoda.
Bought a 2004 Octavia Mk1 a few months ago and whilst the car is mechanically sound, there is an issue with rainwater leaking into the car on the passenger side. After a heavy bout of rain it's a literal puddle. Thankfully the shop vac came in handy to suck most of it up.
I looked through the forum and have already checked the sunroof (drains free running via testing with a Fairy bottle) and had a look near the pollen filter (no debris or damage to the grommet).
Using the trusty watering can to try and establish the cause, it appears (hopefully) to be the rear passenger door.
It looks like the door was taken off at some point (prior to me owning it) and it's not been tightened correctly. I've added some pictures below show what I mean, and the mildew/mold along the seal suggests water is getting in where it shouldn't.
https://imgur.com/a/92Myzd0
How would I go about fixing the door so it aligns properly?
Thanks!
Just to add I was also informed by the prior owner (family friend who moved abroad who owned the car for a short while) that the internal door membrane may be damaged although I can't see that producing the volume of water that's occurred here.
I've been looking into sourcing a replacement for it but an actual genuine part seems to be hard to come by. If the door alignment itself doesn't fix the issue then I'll look further into getting the membrane replaced.
Mine was doing the exact same thing, which resulted from the door membrane not being replaced after it was torn open to fix a busted window regulator.
2" of water in the rear left footwell, which took an absolute age to dry out, even in Summer.
Thankfully the tears were fairly clean and comparatively easy to tape back together again, but really any thick plastic stuck down along the appropriate lines should suffice.
Interesting, in that case I'll have a look at taking off the rear door card tomorrow to check it out and maybe do a makeshift fix.
