The Importance of Entering the Correct Adaption Values for a replacement AGM Battery
Would I be correct in supposing you could use either 1s or 0s (zero) in the 10-digit battery serial number?
Hats off to you for discovering this and for resolving it, I'm sure it must have caused many owners no end of grief and cost and resulted in many ending up offloading a troublesome vehicle by PX when it was not in reality needed.
What would have been the result if you had simply replaced the battery with a similar new one and not recoded at all & then discharged it in the same manner?
It will be ironic if people have been influenced to pay someone to recode the vehicle for a new battery only for them to have actually stuffed things up if doing nothing would in hindsight have been a no risk decision.
I don't know to be honest, but suspect that the binary input values are restricted to the adaption reset field - 'enter new value'.
Certainly an interesting conclusion, which sounds entirely plausible but why would the live data from the diagnostics show the potential battery charge capacity for my depleted battery as being 12.7v at that time, yet the system did not permit it to charge up until the (correct) 'new battery' adaptation had been performed?
I had earlier, once the red battery warning light was on constantly, tried a different variation of the adaptation code, using VAO instead of VA0 and this made no difference - the light stayed on. It was only later on my journey when I changed the adaption code to VA0 with the same sequence of binary numbers that the light went out and the battery started to charge.
This would seem to suggest that entering the code correctly is critical in this situation but it would of course be great to get a definitive answer from VAG.
2 hours ago, Smart Pro said:
Certainly an interesting conclusion, which sounds entirely plausible but why would the live data from the diagnostics show the potential battery charge capacity for my depleted battery as being 12.7V at that time, yet the system did not permit it to charge up until the (correct) 'new battery' adaptation had been performed?
That should be a fully charged battery at that point, and doesn't need charging.
Could be wrong, but happy to be corrected.
VAG don't help themselves, here in the same document... SSP504 Vehicle Batteries
VAO
VA0
Your extremely low SoC from leaving ignition on may have made things go crazy, you kicked the car up the ar5e making it think it had new battery, and it then started Alternator and cleared off the warning lamp.  I agree 100%, only VAG would know this, but getting a definitive answer is difficult (look above for VAO / VA0 in same document)
On 10/12/2022 at 19:00, Smart Pro said:
If you have an AGM battery or equivalent, needed for the start / stop function, the adaption code (the series of 1's after the space, after JCB or VA0 is in binary. Entering the number '2' will be accepted but it is not a binary number and will not result in your new AGM battery being adapted.
This is the only part I disagree with your statement of it needing to be in Binary format (serial number)
Apart from that everything is all good, and should be helpful to others.
