Felicia head gasket nightmare
56 minutes ago, Papez said:
The cables should be acessible if you remove the black portion of the dashboard
Thank you
Good one! Maybe you could describe the photo as example how Not to do it :D
Will do
  • Replies 101
  • Views 10.4k
  • Please note - I am not a mechanic or expert in anything.   Let the 'fun' begin, sooner you than me but I am sure you will enjoy it (for the most part).  Be interesting to see which new parts
  • For sure that is totally for sure for sure.
  • What's the difference between neighbouring inserts? IIRC, there was a limit, too and it is more critical than absolute value. Edges of adjacent liners should be perfectly in level.
16 minutes ago, D.FYLAKTOS said:
9 Euros seems very high, some places here sell it at £5, or even £6, a can but I have bought it for £2 a can or three cans for £10.
22 minutes ago, D.FYLAKTOS said:
PTFE and Teflon are the same thing, Teflon is the trademarked name for PTFE. - https://www.nes-ips.com/teflon-vs-ptfe/
GT85 (history) is owned and marketed by the WD-40 Company (brands), GT85 was started as a British company in the mid-80s but like so much was swallowed up by an American corporation, I have no idea if the WD-40 PTFE spray is exactly the same as the GT85 spray but as I used to successfully use GT85 on my pushbikes in the 1980s I returned to it when it returned to the shop shelves.
Rather than having one can of WD-40 Multi-Use that does not do the jobs as well or several can of specialist sprays I use GT85.
I am also using up gravity and spray can of PlusGas (penetrating/releasing agent) as I bought them before the GT85, PlusGas (history) again used to be a British company but is no more I am not sure if it is now effective as it used to be, but it might be, I have no old cans to compare and anyway GT85 does more jobs and smells nice.
Sounds good to me.
Brakes done.
That was the old brake fluid that came out...
Nasty stuff.
Just a combined photobucket
The valve cover it's Chromium? Plated or painted?
The red letters-logo are Smalto or high temperature paint?
Painted with high temperature paint!
Red nail polish
Which programme are you using for slide-show photos to make the video?
Premier pro
Congratulations!
I wish, you enjoy your Felly in your most happy days and may it serve you well in your hard times, because you served well for it now. :thumbup:
I like how you work on the car. You don't rush your work. You work clean and orderly. I'd trust you to make repairs on my car.
Also your paint work on valve cover looking so very cool. Just loved it.
That was a good idea to record the startup video too. It will be a good memory to remember in the future.
Good work!
4 hours ago, R_Blue said:
Congratulations!
Thank you, haha yes, I think the car is ok for the time being.
Again thank you, this project lasted around 1 and 1/2 months, working when I had free time, but being clean when messing with engine parts is the only way forward for me.
Yes it does refresh the car
Good work!
I have a video of the first start and later starts after MSM adjustments and buttioning everything up!!!
New ac valves installed!
Valve type
CH-9520C
And when I thought I was done the heater matrix failed, the sweet smell of antifreeze filled the cabin. God damn
Oh NO !
VAN WESEL 76006016
about 25 euro, can be found in Greece, for example here and here .
Are you sure it's not the hose(s) or hose clips to the matrix.  I've no idea about the Felicia matrixes but with the old British cars some might think of the matrix are they were a real pain to get out but checking the hose connections would often save the work as few of those matrix leaked even after after 70 years - just about everything else might leak on those cars though.
Edited by nta16
100 percent not the hoses checked many many times...
I replaced mine too.
Also if you used any new coolant hoses and new clamps for those hoses, please remember to check them for leakages for several weeks. It takes some time for them to get used to each other.
+ 1
by ''bitter experience" as we say here.
I replaced mine too
Please inform me of the procedure
In Fav. you start by removing the battery. After that, there are coolant hoses for the heat ex. and the valve control wire. There is a snap on plastic frame which holds the heat ex. in place. (My frame was glued with silicone sealant) After removing that frame, it's easy to replace the heat exchanger. You just carefully pull it from its slot and insert the new.
But...
The large plastic housing which holds the air flaps and the heat exchanger itself is completely different in Felicia.
Heat exchanger position is different too. Looks like it's harder.
I couldn't find a good instruction. All have is this below. Not very helpful and maybe not the correct way to do it but just FYI.
https://www.youtube.com/watch?v=S8rUUqQngGI
https://skoda.7zap.com/en/cz/felicia/fel/2000-101/8/819-819000/
Here is with photos:
https://automend.ru/skoda-felicia/skoda-19685-10.m_id-2029.html
https://www.drive2.ru/l/535038851823960781/
https://www.drive2.ru/l/2844587/
I had few years back the thought to oped it for inspection but my mechanic said ''No, forget it, too much trouble!"
thank you looks like a hard job
