OEM SATNAV
Evening all,
Octavia VRS 5e 2015
Sorry if this has been done to death my apologies, id like to fit a sat nav to my car an OEM direct replacement would be ideal, does anyone have the parts numbers for a compatible item? Please and thank you
HAPPY NEW YEAR!!
Edited by matt_j
What system do you have at the moment?
As you suspect it's been done to death.
Do a search in this section for mib2 retrofit. That should see you good.
Thank you sir ☺️
No idea 🤣🤣
2 hours ago, matt_j said:
No idea 🤣🤣
Hi Matt, you probably have MIB2, if you post a pic. of the infotainment head unit, the system can be identified.
Early 2015 models have MIB1 (like my previous Elegance) as the MIB2 came in in mid-2015 - so @matt_jcould have either MIB1 or MIB2 since he says he has a 2015 model.
My 30th June 2015 is MIB2
But easy to check, just hold down your menu/setup button for about 10 seconds and enter the engineering menu to locate the Software Train.
MSTD_EU_SK_Pxxxx
MST2_EU_SK_ZR_Pxxxx
IIRC the production change happened in May 2015, my 2015 was 29th April 2015 build date.
