Felicia RPM
Hi All , Happy New Year
i changed my Motor from carburerto to Injection but RPM not working
any advice
you need different dash as well as the proper wiring loom
  • 4 weeks later...
It might be possible to fix this problem: if your engine runs normally with the injection. The dashboard takes a signal from one of the ignition coil terminals, I don't know which one, you need an electrician, but there will be a pin on the ECU connection,which gives a signal for rpm, and you should be able to join the two wires together, then hopefully the guage will work.
