Offside Rear fog lamp not working (4.5.1 (a) (ii))
Hi Guys,
I got Skoda Superb mk3 2016 hatchback diesel 2l 150bhp. I done the MOT but got some minor warning. They said the fog lights not working but the problem i got i try buy new lamp because can't change the bulb because its led lights. Then I try to find replacement part but the problembi got its only for left rear tailgate lamp with Fog function can't find any right lamp. I even contacted the HELLA who produced those lamps directly and they states that fog light is in left lamp not right. PLEASE HELP ME
A single rear fog is always fitted to the offside/drivers side..........
& the UK MOT requirement is a Rear Fog Light Offside or Centre.
Not sure why it gets just a 'Minor'   But then plenty cars from outside the UK are going about in the fog with a nearside only fog
or even no rear fog on just like UK cars..
I know that. It's English car. But as I said I contacted directly to company who produce those lamps and they said it only nearside lamp (left one) had a fog on it.
  • Sponsor
Skoda dealership should be able to get the correct part for you.
Did you tell them it’s for a RHD car? Because, they might have thought you were talking about a LHD one.
The rear fog light is on the left on my french LHD Mk3.
I assume you did, but just to check. Sometimes we forget the most obvious things ;)
Problem nearly sorted. Lamp. Is working i checked on other superb same as mine. The problem I got its not working on my car. All lights working apart of fog light. Don't know if it headlight switch or cables. But headlights switch is damage I accidentally use too much power and knob turned 360 degrees and fall. How to remove the headlight switch without that hob?
