Software Update available for Bolero?
ThanksHi ,I have a Skoda scale my2019 with h12 ,currently I have software MOI3_EU_SKMQB_P27600P_MU0276
I know there is version 0306 or newer, where can I find it?
Thank you
Mah I don’t have bolero but admudsen
  • Replies 769
  • Views 208.5k
  • StripleRider03
    StripleRider03
    I just updated to 1800, I have a Skoda Slavia in India with the Bolero system. I can confirm that the issue with S23 Ultra is finally resolved! Attaching images.
  • radoszczak
    radoszczak
    Cześć, poniżej link do strony z opisem możliwych FW U Ciebie powinno pójść do wersji 742. https://www.drive2.ru/l/650934799095051499/
  • There are these updates, but not sure if the higher number will apply to your system.   MEN3_EU_SK370_P0113P_0469 MEN3_EU_SK370_P2135P_0742   MEN3_EU_SK370_P1185L_1760 ME
Hi, would you be able to turn over the file that I couldn’t download yesterday on my way to work?
Would you do me a big favor
Hi, I have a Skoda Scala 2019 model, and my AA isn't working with my Android 13 phone.
I also have the Bolero system. I wonder if an update would help? 😀
Maybe, but won't know unless you provide details of the Software Train.
I have SW Train MEN3_EU_SK370_P9305P
And MU SW 0463
And MU SW 0463
MU 0469
I can send you this by Private Message
I also have Kamiq Bolero with MEN3_EU_SK370_P0393L / 1310 and trouble with AA. Can I have an update  to 1790?
Yes I can send it to you
if you have a MEN3_EU_SK370_P9305P then you need to update to MEN3_EU_SK370_P0113P MU0469 and from there you can update to MEN3_EU_SK370_P0393L MU1310 and then to MEN3_EU_SK370_P2345L_MU1790
I have the MEN3_EU_SK370_P9305P but was unable to install the MEN3_EU_SK370_P0113P update. The update button just stayed gray when I insert the USB.
Did you prepare the usb properly? If you have sd slots, try a SD card. Also use a Windows pc, format the card/sd and put the Data + Meta folder into root of the folder.
Use service menu to update. I have updated several to latest version, starting from same version as yours.
Yes I did exactly that. My issue is I only have USB-C connectors in the car, unless there is a hidden SD card slot.
I also only have a 128 GB USB where I just put the Data and Meta folders, in the root.
I've tried formatting the USB as exFAT and NTFS.
As i can't edit my own post....
Made a mistake,  After P0113P, update to MEN3_EU_SK370_P2131P MU0741 and then to MEN3_EU_SK370_P2345L_MU1790
I will check in a hour or so for you.
Thanks!
45 minutes ago, plasmagoat said:
Thanks!
You have PM
Thank you
324 is the latest. Is a two stage update to 324.
You have the 324 version?
yes i have it
but the Skoda version? could you turn it around?
Yes Skoda version. What do you mean?
I thought you had the Volkswagen version
Have you noticed any differences or improvements?
I also have the VW version. Yes faster and more responsive
could you send me the file? I would be grateful
No unfortunately not yet. Maybe @varooomcan sent it to you
I have the files, but remember you could break your system @Giuseppe82
So please let me know here if you still wish to try this out...
So far no problems after updating from 270 to 324. Done several cars
