Software Update available for Bolero?
On 17/11/2026 at 11:01, k00ks said:
Hi guys,
My radio was stressing me so I bit the bullet.
These were my steps... (0742 maybe not needed but I did it anyway)
0463 → 0469 → 0741 → 0742 → 1790 → 1798 → 1800
Radio seems to be working ok, my wifes car so I haven't spent mych time in it.
Looks good and works with my phone now.
Massive thanks the everyone on here who helped but especially to the tech-savvy heroes who risked their own radios, that first upgrade is the hardest!
Hi @k00ks , @Everyone thanks for sharing your successful upgrade!
My 2019 Scala has a Panasonic Bolero MIB3 (P/N 654035871B, HW 033, SW 0463). Two USB-C ports below my Scala's infotainment screen. I've already tried several cables, including the original Samsung cable, without success.
I've had persistent Android Auto issues with my Samsung Galaxy S23+.
Could you confirm your hardware version and whether your upgrade path to 1800 would work on my unit? Any advice would be greatly appreciated!
Screenshots attached. Thanks!
Edited by pervp
  • Replies 787
  • Views 228.9k
  • There are these updates, but not sure if the higher number will apply to your system.   MEN3_EU_SK370_P0113P_0469 MEN3_EU_SK370_P2135P_0742   MEN3_EU_SK370_P1185L_1760 ME
  • It's on the page you posted, "Service Update button" and a USB stick. I will send you some instruction and links. They have an emergency menu for recovery.. so you would have to have a defe
  • StripleRider03
    StripleRider03
    I just updated to 1800, I have a Skoda Slavia in India with the Bolero system. I can confirm that the issue with S23 Ultra is finally resolved! Attaching images.
Quick update: My SW Train is MEN3_EU_SK370_P9305P.
MIB-Helper lists MEN3_EU_SK370_P1185L (MU 1760) as the latest available firmware.
Has anyone successfully updated this SW Train to 1760 or 1800?
Edited by pervp
Hi @pervp ,
This is exactly where mine was the other day.
Get the firmware's for each step.
Put them onto a USB stick, one version at a time. (skip 0742 that I did)
You should have one folder on your USB root - MEN_EU_SK370.... or similar, inside this you should have 2 folders - Data, and Meta.
I used an old 16GB USB with a USBC to USBA adapter cable.
Good luck!
Edited by k00ks
Hit enter too soon
5 minutes ago, k00ks said:
Hi @pervp ,
Getvthevfirmware fire each
Brilliant! Was yours also HW 033? Could you please share the firmware download links you used? Thanks!!
@k00ks Thanks again. Just one final question before I attempt the update: was your unit HW 033 or HW 040? Mine is HW 033, currently on SW 0463.
Also, could you confirm that your original SW Train was MEN3_EU_SK370_P9305P, exactly like mine?
@CrazySkoda listed additional intermediate versions, whereas you successfully used 0463 → 0469 → 0741 → 0742 → 1790 → 1798 → 1800
Can I safely follow your shorter sequence on HW 033, or are the additional steps necessary? Thanks!
@CrazySkoda, do you know whether the same upgrade path to 1800 is safe for HW 033?
Really appreciate your help!
Edited by pervp
Mine is 040, I can't say if that makes a difference. I'm sure it's no different than installing an OS on a desktop or a Laptop.
I had a connectivity issue that was frustrating me, so went through the process.
Good luck!
@CrazySkoda @varooom Hi,
@k00ks has confirmed his successful upgrade to 1800 was on HW 040, whereas mine is HW 033.
Do you know whether HW 033 supports firmware 1800, and whether your longer upgrade sequence is necessary?
I'd really appreciate your advice before attempting anything. Thanks!
16 hours ago, k00ks said:
Hi @pervp ,
Good luck!
Thanks for the additional instructions for the USB! Hi @k00ks , one last clarification: do you know if the firmware files you shared compatible with both HW 033 and HW 040, provided the SW Train is identical (MEN3_EU_SK370_P9305P)? Or are there hardware-specific firmware packages? I want to avoid bricking my HW 033 unit. Many Thanks!
@pervp Have a look at my last post.
Godspeed!
Thanks @k00ks , appreciate your help!
@CrazySkoda @varooom @andreiro221 I've investigated the firmware packages further and found something interesting:
  • Both 0469 and 1800 have exactly the same Variant (FM3-E2-*-*-SK-MQB-PA-*) in their main.mnf manifests.
  • Both also have identical BlockedTrains lists, which don't include my current MEN3_EU_SK370_P9305P.
  • The 1800 emmc_device manifest doesn't explicitly restrict HW 033 either.
This suggests the P/L suffix doesn't necessarily indicate hardware compatibility, although matching manifests alone don't guarantee a safe update.
Has anyone successfully upgraded an HW 033 unit to 1790/1798/1800?
I'd particularly appreciate confirmation before risking my infotainment unit. My main objective is fixing Android Auto connectivity with my Samsung Galaxy S23+.
Thanks.
Hi all!
2019 Scala, Bolero MIB3, HW 033, SW Train MEN3_EU_SK370_P9305P, MU SW 0463. Could someone kindly PM me the files for 0469, 0741 and 0742? And has anyone done this on HW 033?
Thanks a lot!
Recently Browsing 2
