Temp gauge rising,fabia mk1
Thanks for everyone's help.
Water pump was broken.
  • Sponsor
Well done, glad you found the problem.
I thought that lack of return flow in the little hose at top of expansion tank was pointing in that direction.
Yes that did get me thinking and pump was a first line one just under £30 ... fitted myself.
As for the output test,it doesn't give you an option in vcds,but the fan was kicking in this morning,so I know that works.
I noticed when I was driving after fitting the water pump,temp gauge was dropping lol...think got a airlock....heaters are hot now though.
  • Sponsor
I find it always takes a journey or two, as opposed to just letting it sit idling, before the coolant level settles down after any such change.
Make sure it's got enough antifreeze in, fair chance a freeze-up was what killed the old waterpump I should think. Probably why the previous owner got rid?
Or just old age; I've known very few plastic impeller water pumps make it past 1.5 cambelt lives.
After doing over 70 miles,temp gauge sits at 90 until I start driving and slowly creeps down and sits at 50......I've left the cap off the expansion bottle for over an hour,heaters on etc, still the same, never did that until I changed the water pump.
Do you guys still think there is an airlock?
  • Sponsor
Maybe previous owner took thermostat out?
Good shout, I'll probably check it probably on Saturday....will let you know.thanks
If I have time will be checking it today.
Could it still be the thermostat as it gets to 90 like normally and then drops , when driving, wouldn't it take a very long time to reach temp?
This takes about 10 minutes or so.
  • Sponsor
Indicated 90 covers a pretty big span of reality, so yes, still possible I would think.
I'll check it out, cheers.
