Brake disc size
Hi all,
New Owner here :)
I have a 2018 Mk3.5 octavia VRS, and wondering what size the front and rear discs are, (without taking the wheels off and measuring them haha)
Any advise on the best way to find this out and any recommended brands to go for or avoid (standard)?
4 hours ago, RossMacGill said:
I have a 2018 Octavia MK3.5 VRS, and wondering what size the front and rear discs are, (without taking the wheels off and measuring them haha)
If it's an Octavia MK3 facelift petrol 245HP VRS, it's 340x30mm front and 310x22mm rear.
If it's an Octavia MK3 facelift diesel 184HP VRS, it's 312x25mm front and 272x10mm rear.
If it's an Octavia MK3 pre-facelift VRS petrol or diesel, it's 340x30mm front and 272x10mm rear.
Edited by Carlston
Thanks, I guess i have the only one you didnt list haha, its a 230 Petrol facelift haha, so would i be correct in thinking its 340x30mm front and 272x10mm rear?
The facelift model came out in 2017 and has split front headlights.
The Octavia MK3 petrol VRS 230HP came out in 2015, so is pre-facelift.
All of the Octavia MK3 petrol VRS cars have 340x30mm front discs.
On the Octavia MK3 VRS it's easy to tell what size the rear discs are because the ventilated rear discs are 310x22mm and the solid rear discs are 272x10mm.
Octavia MK3 petrol VRS engines
2.0 TSI RS 162 kW
(RS 220)
2013- CHHB (EA888-Gen3) 1984 ccm, I4, 16V DOHC, TSI, turbocharged 162 kW (220 PS; 217 hp) at 4500-6200 rpm 350 Nm. (258 lb•ft) at 1550-4400 rpm 6-speed manual (MQ350), FWD 248 km/h (154 mph) 6.8 6.2 / 45.6 / 37.9 142
2.0 TSI RS 162 kW
(RS 220)
2013- CHHB (EA888-Gen3) 1984 ccm, I4, 16V DOHC, TSI, turbocharged 162 kW (220 PS; 217 hp) at 4500-6200 rpm 350 Nm. (258 lb•ft) at 1550-4400 rpm 6-speed DSG (DQ250), FWD 245 km/h (152 mph) 6.9 6.4 / 44.1 / 36.7 149
2.0 TSI RS
169 kW
(RS 230)
2015- CHHA
(EA888-Gen3)
1984 ccm, I4, 16V DOHC, TSI, turbocharged 169 kW (230 PS; 227 hp) at 4700-6230 rpm 350 N⋅m (258 lbf⋅ft) at 1,500–4,600 rpm 6-speed manual (MQ350), FWD 250 km/h / 247 km/h
(155 mph / 153 mph)
6.7 6.2 / 45.6 / 37.9 142
2.0 TSI RS
169 kW
(RS 230)
2015- CHHA
(EA888-Gen3)
1984 ccm, I4, 16V DOHC, TSI, turbocharged 169 kW (230 PS; 227 hp) at 4700-6230 rpm 350 N⋅m (258 lbf⋅ft) at 1,500–4,600 rpm 6-speed DSG (DQ250), FWD 249 km/h / 245 km/h
(154 mph / 152 mph)
6.8 6.4 / 44.1 / 36.7 149
2.0 TSI RS
180 kW
(RS 245)
2017- DLBA
(EA888-Gen3)
1984 ccm, I4, 16V DOHC, TSI, turbocharged 180 kW (245 PS; 241 hp) at 4,700-6,200 rpm 370 N⋅m (273 lbf⋅ft) at 1,600–4,300 rpm 6-speed manual (MQ350), FWD 250 km/h
(155 mph)
6.6 / 6.7 6.6 / 42.8 / 35.64 150
2.0 TSI RS
180 kW
(RS 245)
2017- DLBA
(EA888-Gen3)
1984 ccm, I4, 16V DOHC, TSI, turbocharged 180 kW (245 PS; 241 hp) at 4,700-6,200 rpm 370 N⋅m (273 lbf⋅ft) at 1,600–4,300 rpm 6-speed DSG (DQ250), FWD 250 km/h
(155 mph)
6.6 / 6.7 6.4 / 44.1 / 36.7 146
2.0 TSI RS
180 kW
(RS 245)
2017- DLBA
(EA888-Gen3)
1984 ccm, I4, 16V DOHC, TSI, turbocharged 180 kW (245 PS; 241 hp) at 4,700-6,200 rpm 370 N⋅m (273 lbf⋅ft) at 1,600–4,300 rpm 7-speed DSG (DQ381), FWD 250 km/h
(155 mph)
https://en.wikipedia.org/wiki/Škoda_Octavia
Edited by Carlston
Thanks for the information, it was build in Jan 2018 and has the split headlights and is a CHHA, so its a 230 :)
So are the rear discs ventilated or solid?
Jurid on autodoc lists the 230HP model as having solid rear discs.
Build code 1KT means 272x10mm solid rear discs.
Build code 1KW means 310x22mm ventilated rear discs.
Edited by Carlston
  • Sponsor
@RossMacGill Chuck me your VIN by private message, I can look up.
  • Sponsor
Your front brake PR code is 1LG, 340mm discs; rear is 1KT, the 272mm solid 10mm thick discs.
Edited by Breezy_Pete
If anyone want to check their disk  size  without taking the wheels off you can measure them with a pair of large divider's through the wheel spokes.
No dividers just clamp 2 bits off metal with mole grips so they rest on the disk edge
On 28/03/2023 at 20:14, RossMacGill said:
Hi all,
New Owner here :)
Metal coat hanger bent to measure discs.
I've just bought EBC plain discs with black coating and yellow stuff pads.
Hopefully fitting over Easter.
Didn't think  of a coat hanger, Good effort.
Were did you get your disks from please? Cheers
www.ebcbrakesdirect.com
Don't forget topcash back as well!
Is there not something simple to tell with these? The 340s have a small bend in the calliper carriers and the 312s are flat/straight?
Just as I mentioned EBC brakes, I fitted them over this weekend.
Went for plain discs and yellow stuff pads. I did want drilled, or slotted for a sportier look, but my brother has cracked discs like this before, so thought I'd just stick with plains.
But initial impression is they are quite good, initial bite seems very impressive from cold.
My only quibble is, the rear discs were all black and as you bed them in, the surfaces go silver and leaves a black hub center and outtet edge.
The fronts were their 'gen 2' discs which are only black on the hub and silver only the outer edge, but I wanted black! I could have phoned up and swapped them, but instead I just sprayed them black, with some heat resistance paint.
Hopefully it lasts a while!
I also sprayed the rear disc guards wit h galv spray, then black, as they were a bit rusty.
I've just Received some New Discs from M-Tec, Had them before and brilliant quality for the price these are grooved as well, Originally have the 282mm on the front of my 2017 octavia 4x4 2.0 diesel, But for a bit of extra dosh Ive got the caliper mounts and some pads and discs, will be getting them on in the coming weeks.
I was looking at m-tec, but they didn't have some stuff in stock and I wanted to do it now.
