Steering / tracking mystery finally solved
Nice one and we’ll done for persisting too. 👍🏻
When you say “turning itself very slightly to the left” did that mean you had to constantly apply pressure to the wheel to correct it to the right?
I have an annoyance with the steering wheel, in that it’s aligned to the left and it’d have to be set “between splines” to correct it. The tracking is spot-on so I’m loathed to get it fiddled with and “tracked out”, cos as sure as eggs are eggs, they’ll fe*k it up and I’ll have shredded fronts in 1000 miles. 🙄
The wheel would move slightly to the left every time I let go of it.  If I took hands completely off, it would be pretty much straight, but any bumps etc and it would move slightly left.  The car drove straight.
I knew something wasn’t right beyond the tracking.  It’s possible your steering angle sensor is not correctly set, like mine?
Other things I checked were suspension and steering components and tyres - their wear, whether rotating the right way, change left to right etc.
The old dampers were creaking at slow speeds when I first set off in the morning and over-bouncy.  The new ones are quiet (for how long who knows) and firmer.
Good luck getting to the bottom of it! It is definitely worth persisting! Once it is right, it just feels perfect - tracks straight and turns in well.
Mine seems also to be a bit out to the left too.
Do we think the steering angle sensor is something we can rectify through Obd11 after an alignment?
No idea.  I’m sure someone on here will know though!
Ohhh mine does the left thing too had it all aligned etc etc and still same. Well mine if I put the wheel straight the car goes right a tad. Straight and the steering wheel is ever so slightly to the left
Maybe worth getting the steering angle sensor checked.
Of course, most of our roads are cambered, so worth taking it across to the right side of the road (when safe to do so! 🤣) and seeing what effect that has.  On mine, before the fix, I did this and just had to steer even further to the left to keep going straight.
Same here I always feel my steering wheel is ever so slightly off centre to the left then going straight. Tracks straight so I just accept it.
Seems a few have wheel slightly to the left….
During my 4 alignments, one guy who seemed decent enough, said that in the UK cars are set up to drift slightly left if the driver is no longer steering for any reason (e.g. medical emergency) so head-on collisions are less likely.  And the opposite on the continent.
Wasn’t sure whether he was talking tosh or not.  I would have though natural camber would suffice.
Anyway, I’m not a mechanic.  Perhaps someone else knows more?
Someone who knows more? Must be another mechanic 😆
Many mechanics will (believe they) know more than anyone else and trot out no end of memorable lines like that.
same problem for me too,tracks to the right, is  LHD.
I managed to solve it just by rotating wheels rear to front for winters (16 inches with brand new wredestein tyres)because they are directional tyres.
Switching to summer wheels 18 the tracking coms back and solved it second time by inverting front wheels,non directional Pirelli P7
Because of soft control arm bushes I found the car being very sensitive to road inclination.
Edited by IulianE
Interesting and in particular your last point.
There is no doubt the Superb is sensitive to the road camber / inclination.
You need to get the tie-rods adjusted equally but opposite (one lengthened, one shortened) so that the rack is centred while the wheel alignment stays the same. This happens because most garages won't do more than adjust one tie-rod to get the toe-in correct, which leaves the rack off-centre.
