Your friendly local dealer
Thanks to all, for the replies. just alittle note to anyone with a skoda, as your friendly workshop manager at the local dealership if you need any assistance with any aspect of your skoda car please email myself , from software mods to everyday maintanance i will endever to assist you to the best of my ability :drive:
You open this Saturday?
I need:
New headlamp motor (ns)
New drivers seat (lumbar adjustment fubar)
New gearbox - syncro on 2nd has gone AWOL
:D
I need:
:D
Warranty jobs ?
Geoff, there appears to be one missing from your list :D
Don't be coy Dave, why not post the full address of your dealership here.
why strip it, just fit a new one.
Dave, that's why I said new gearbox. However, I think Skoda warranty will tell me to bugger off, like they did when my engine went bang :( Now, if a dead MAF had been diagnosed in the first place........
Dave,
If I PM you my reg number/chassis number, do want to try and put it through on warranty? Fault is that there is no syncro on 2nd gear.
I'll give you 3 to 1 they turn it down.
unfortunatly sounds as if your dealer didnt uderstand measuring value blocks.where he or she would have had live data for your mass air.....
Dave...
Advice on this one would be good...
My 14K mile Octavia vRS.. seems to have a problem or two....
I need to know if other Octavia vRS owners suffer the same problems
when travelling over roads with bumps in them ( 99% of UK roads ) at around 30-40mph .. It seems that there is something clonking from the front end of the car, as the car hits a 'bump' in the road the suspension reacts bit there is
sort of a loose clonk at the same time ,, like the wheel nuts are loose ( they aren't ) ?? It does'nt happen all the time though.
Also the rear of the car on these roads clonks and bangs .. This was not on the car only up until recently..It feels like the back doors are moving against the body....
I travel these roads daily...
Also there is play developing again in the Steering wheel,, rocking it left and right through the rest.. This has already been sorted once before ( steering column was replaced )...
Any ideas... Or does anyone else suffer this problem?
Second problem is with my Symphony Radio Cass unit that keeps displaying the
MECHANIC in the display, this is cleared by ejecting the CD magazine.. Dealer
has said it is a fault in the HU.. but they cannot replace it as SKODA warranty
has to prove there is indeed a fault before the unit is replaced, this means that
I would have to send it off for repair!! Strange but Seat and VW warranty never had this clause in them ..
cheers
Dazz
Dave...
when travelling over roads with bumps in them ( 99% of UK roads ) at around 30-40mph .. It seems that there is something clonking from the front end of the car' date=' as the car hits a 'bump' in the road the suspension reacts bit there is
sort of a loose clonk at the same time ,, like the wheel nuts are loose ( they aren't ) ?? It does'nt happen all the time though. [/quote']
I will stand aside when a pro gives a proper answer to this one ;), but doesn't that sound like the anti-roll bar bushes?
  • Administrators
Same here, mine does this, low speed say with a bot of lock over a speed bump...strangely enough going over a speed bump with a bit of pace they don't do it.
Ask dealer to drive same route (or mecahnic) reproduce statically by full lock and bouncing car on wing...might help, did for mine at least to get prob;lem looked at, which was basically striping down and lubricating them. Comes back every now and again.
Aren't you trying to sell your car Colin? :ignore:
Dave...
cheers
Dazz[/quote']
first fault sounds like antiroll bar or bushes or link rods second problem symphony radio's are not repaired but replaced if you have the old grundig radio then they will be repaired but if you try sending a symphony of for repair radio repair shop will send it back and say see skoda warranty.
