Space saver size
Wil6714
Recommended Posts
4 hours ago, Wil6714 said:
Just bought Skoda Superb Sport line Plus 2018
Looking to put in a space saver what size would I need if wheels are 19's?
All Superb MK3 cars can use 16" wheels, except the 272HP/280HP 4x4 models which need 17" wheels to clear the front brake calipers on the 340x30mm front brakes discs.
So if you don't need 17" wheels, you can use a 215/60R16 tyre fitted to a 6Jx16 ET43 rim (from the Karoq). This will fit flush in the spare wheel well. Surprisingly, a  215/60R16 tyre fitted to a 6.5Jx16 ET41 rim (from the Superb MK3) won't fit flush in the spare wheel well. Hence, the benefit of using a narrower 6J rim from the Karoq.
As you can see in the chart below, 215/60R16 fitted to a 6J rim has an actual inflated width of 215mm. On the Superb MK3, that's the limit for the spare wheel fitting flush in the spare wheel well.
Actual width of inflated tyres
215/60R16 fitted to 6J rim = 215mm
215/60R16 fitted to 6.5J rim = 221mm
The 16" spare wheel would also work on the Superb MK3 272HP/280HP 4x4 models, but you could only use it as a rear wheel. However, many people who use a space saver prefer to use it only on the rear.
Alcar 6665 6Jx16 ET43 5/112 57.1 steel rim (from Karoq)
https://www.oponeo.pl/felga-stalowa/alcar-kfz-6665/23323157
Alcar 8426 6.5Jx16 ET41 5/112 57.1 steel rim (from Superb MK3)
https://www.oponeo.pl/felga-stalowa/alcar-kfz-8426#22943187
Edited by Carlston
  • Like 1
Link to comment
Share on other sites
2 hours ago, Dooge said:
The MK3 Octavia VRS won't accept a 17" due to the size of the brake caliper.
The Octavia MK3 VRS uses either 312x25mm or 340x30mm front brake discs.
15" rims will clear the front brake calipers on cars fitted with 288x25mm front brake discs.
16" rims will clear the front brake calipers on cars fitted with 312x25mm front brake discs.
17" rims will clear the front brake calipers on cars fitted with 340x30mm front brake discs.
Edited by Carlston
  • Like 1
Link to comment
Interesting, I always thought that 18's were needed for VRS' but happy to learn otherwise.
Any idea what size the 17" and 18" space saver tyres are? I'm trying to work out diameters they are in comparison to current 19"s, ideally to find similar if possible.
Edited by Dooge
Link to comment
On the Octavia MK3, a 205/55R16 fitted to a 6.5Jx16 ET46 5/112 57.1 steel rim could be used as a spare. If it's a VRS with 340x30mm front brake discs, the 16" spare wheel could only be fitted to the rear.
Another option is 125/70R18 fitted to a 3.5Jx18 ET25.5 5/112 57.1 steel space saver rim. However, as there is enough room in the space wheel well for at least a fully inflated 205/55R16 it seems a bit pointless using a 125/70R18 space saver. The space saver may be thin, but it's very heavy. Being able to inflate the space saver up to 4.2 Bar (60psi) requires a heavy duty construction of the tyre and rim...hence you are unlikely to save much weight by going down the space saver route.
As you can see in the chart below, the outside diameter of all these tyre sizes are very close. There's less than 1.3% difference between any of them.
Outside diameter of tyres
125/70R18 632.2mm
195/65R15 634.5mm
205/55R16 631.9mm
205/50R17 636.8mm
225/45R17 634.3mm
225/40R18 637.2mm
225/35R19 640.1mm
If you want a cheap 17" steel rim to use as a spare, you could use a 6.5Jx17 ET38 5/112 57.1 steel rim (from Kodiaq) fitted with a 205/50R17 tyre.
Alcar 8247 6Jx16 ET48 5/112 57.1 steel rim (Octavia MK3 winter tyre size)
https://www.oponeo.pl/felga-stalowa/alcar-kfz-8247#22880278
Alcar 8667 6.5Jx16 ET46 5/112 57.1 steel rim (from Octavia MK3)
https://www.oponeo.pl/felga-stalowa/alcar-kfz-8667/23124463
Alcar 9021 6.5Jx17 ET38 5/112 57.1 steel rim (from Kodiaq)
Alcar KFZ 9021
https://www.oponeo.pl/felga-stalowa/alcar-kfz-9021#22767779
Octavia MK3 VRS foam and jack kit 5E0093860C (you should be able to order this from a Skoda parts department using the OEM part number 5E0093860C for about £50, so you just need to add the spare wheel)
Sada pro výměnu rezervního kola
https://eshop.skoda-auto.cz/cs_CZ/sada-pro-vymenu-rezervniho-kola/p/5E0093860C
Octavia MK3 non-VRS foam and jack kit 5E0093860E (you should be able to order this from a Skoda parts department using the OEM part number 5E0093860E for about £50, so you just need to add the spare wheel)
https://eshop.skoda-auto.cz/cs_CZ/sada-pro-rezervni-kolo/p/5E0093860E
Edited by Carlston
  • Like 1
  • Thanks 1
Link to comment
Sounds like a sensible solution. I suspected all of them would be similar size wise so Speedo readings and vehicle heights arnt modified too much. I was hoping to pick up a second hand 17" or 18" space saver as a spare but may price up a cheap steel replacement. As the wife uses the car I don't want to get a 16" if it only goes on the back, I don't trust the scissor jack to try swapping 2 wheels if the front blows.
Link to comment
There is an 18" space saver rim listed in the Skoda parts catalogue for the Octavia MK3. There's usually a large number being sold on ebay with this OEM part number, ie. 1K0601027AP, usually with a 125/70R18 space saver tyre. Always check the tyre size with any seller, because there's other 18" space saver tyres such as 125/60R18 and 135/80R18 that won't be correct for the Octavia MK3.
3.5Jx18 ET25.5 5/112 57.1 space saver steel rim 1K0601027AP (from Octavia MK3)
1 1K0601027AP Steel rim for
space-saving emergency wheel
3.5Jx18 ET25.5 1 PR-1G9
  1K0601027AP 03C rally black
https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/805/6/601/601012
Edited by Carlston
  • Love it! 1
Link to comment
On 19/06/2023 at 19:44, Wil6714 said:
Hi all,
Looking to put in a space saver what size would I need if wheels are 19's???
Tyia
I will have virtually brand new space saver for sale from my March 23 Superb - send me a PM if interested.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
