MIB 2.5 Retrofit minor issues
Hello. I have upgraded from MIB 1 to MIB 2.5 and I have 2 small issues that need solving.
1. In the sport  information menu (or whatever it's called), the boost and temperature gauges are not displaying anything.
2. The clima menu is completely not functional.  It doesn't display anything and the menu button from climatronic panel also doesn't do anything anymore.
Does anyone have any experience with what needs coding?
Ask pab, he is the expert here
@pab567any idea?
1. too old firmware in ECU, cluster and / or gateway. Might be not possible to get this info even after SW upgrade - depending if the latest firmwary for these modules support it.
2. Mafe adaptation channels map from VCDS and send via PM (pl suse English version of VCDS).
Fixed these issues by upgrading the gateway module to 3Q0..  and correctly coding the climatronic unit. Turn out that the hacky vcds I've had was too old and the climatronic unit was not getting coded actually.
