Quick question: where is the A/C Pressure Switch (F129) located on a Roomster
Hello all.
Car is a Roomster 1.6 petrol from 2008/2009 (BTS) with Climatronic.
Aircon compressor won't kick in, and I get these codess:
01274 - Air Flow Flap Positioning Motor (V71)
            000 -  -
00792 - A/C Pressure Switch (F129)
            000 -  -
I hope you can help with finding the F129 - I can only find the G65 when looking on the car.
I've checked service manuals, wiring diagrams and all, but I cant find its location.
Any help will be much, much appreciated!
All the best,
Kasper
  • Sponsor
What device has generated those fault codes? I suspect it is not giving good information.
No F129 in any Roomster circuit as far as I can see, therefore it doesn't exist, G65 is doing that job instead (and better).
Hi, Pete.
I'm using a rather cheap HEX/usb-thing, so I was a bit uncertain and suspected what you just pointed out - no F129 but G65 instead.
Glad to hear I'm not blind :) - and that I can stop looking for it and focus elsewhere.
Compressor won't kick in, so I'll have to figure out a way to test if clutch is getting power/data/else that tells it to engage. Right now it just seems offline/dead.
Thanx a million for the quick answer, Pete!
- Kasper
  • Sponsor
You won't find a clutch on your compressor either. Proportional solenoid valve N280 varies the displacement of the pump, axle is always spinning.
  • Sponsor
Broken wires on the way to N280 is certainly one possible failure that might explain your troubles.
Fantastic!
I'll do that tomorrow - thank you so much, Pete.
