Superb Scout edition harsh suspension
9 hours ago, Tonies said:
1. As far as I know - the pro kit from Eibach its a sports springs - which means difficult ride on bad roads which are plenty here.
2. Also, if it is for Kodiaq - does it mean it should not drop too much compared my raised suspension?
3. And how they will fit with the B6s from Alltrack?
1. it's far away from sport, stiffer for 15-20%
2. that was my goal, get some extra stiffness and avoid lowering
3. no info, haven't met any resource with Bilstein's production sizes
like this https://size.name/en/catalog/pruzhiny
  • Replies 75
  • Views 14.4k
  • I may be wrong. But if you take a look at each spring, transport blocks are big enough, so that they can’t be missed. No real need to go to a dealer to check if they’re still ON. 😉
  • Have you checked the transport blocks have been removed. They fill in some of the from suspension to reduce the body movement in transport. Some dealers forget to remove them. They are usually in the
  • I agree, this forum is flooded with what later turns out to be BS because people believe what a garage tells them.   Check yourself by jacking the car up and lifting the piston rod shroud, t
