Will 225/45 R17 fit Skoda Rapid?
Looking for some new wheels as the ones on my new car came with a lot of kerb rash.
Will 225/45 R17 fit Skoda Rapid? Anyone using this size and find them OK?
Sounds pretty big (wide) / tall without me even doing a comparison on the various sites for comparing tyre sizes.
An idea would be to say what tyres are on now.
Are they 205/40 R17 ?
Those that know Rapids or google them might know.
@Carlstonwill likely be able to tell you about sizes,
or there are the threads in this section or the tyre section if you looked.
http://briskoda.net/forums/topic/504236-tyres
Edited by toot
As you can see below, 225/45R17 is an Octavia MK3 tyre size.
Fabia MK3 and Rapid tyre sizes
175/70R14
185/60R15
215/45R16
215/40R17
Octavia MK3 tyre sizes
195/65R15
205/55R16
225/45R17
As you can see below, the outside diameter of 225/45R17 is 5.1% bigger than 215/40R17. So is too big for the Fabia MK3 and Rapid. Also, 225/45R17 is likely to rub on the Fabia MK3 and Rapid.
Outside diameter of tyre
215/40R17 603.8mm
225/45R17 634.3mm (+5.1%)
If you're looking for slightly oversize tyres, then 195/60R15 fitted to the standard 6Jx15 ET38 5/100 57.1 rims would be a good choice. One advantage of the 195/60R15 tyre size is that it's an economical tyre size. One advantage of 15" rims is that they are lightweight.
Vredestein Quatrac 6 195/60R15 88H (Euro label C B 70dB) (all-season tyre, 3PMSF symbol) (about £62.90)
Vredestein Quatrac
https://www.camskill.co.uk/m138b0s7993p202144/Vredestein_Tyres_All_Season_Car_Vredestein_Quatrac_6_195_60_R15_88H_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_B_NoiseClass%3A_B_Noise%3A_70dB
6Jx15 ET38 5/100 57.1 alloy rim MATO (3559CZK is about £126.67)
Alu kolo MATO 15" Rapid, Fabia III
https://eshop.skoda-auto.cz/cs_CZ/alu-kolo-mato-15-rapid-fabia-iii/p/6V0071495++8Z8
Alcar 7760 6Jx15 ET38 5/100 57.1 steel rim (about £40.00)
ALCAR 7760
https://www.mytyres.co.uk/rims/details?vehicleId=666952208536835172&rimCode=ALCAR7760
Edited by Carlston
175/70R14
185/60R15
215/45R16
215/40R17
195/65R15
205/55R16
225/45R17
215/40R17 603.8mm
Vredestein Quatrac
ALCAR 7760
Yeah, they absolutely don't rub. Source: I run them.
