Yeti 2017 Dash lights on - warnings and fix!
Presented with a lot of warning lights the other day in the middle of a short trip - ABS, Brake, Power steering, TCS, ESC, AFS!
I have a vagcom Hex Interface and was able to scan for faults. Came back immediatly after reset. I thought that it may be the battery as odd stuff can happen if battery is low. After much reasearch I was inclined to check the rear left wheel speed sensor - All looked fine - Easy to reach just behind wheel. Sprayed the heck out of it with some liquid maintenance and waited a while. Took it for test drive and all warning lights are now out.
Thanks too all the web sites and utube info I was able to fix it myself and will be able to replace the sensor.
New sensor ordered - Ebay.
Hope this helps someone
John
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
5F-Information Electr. -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
1 Fault Found:
17158 - Databus
U1123 00 [046] - Received Error Message
Intermittent - Confirmed - Tested Since Memory Clear
5 Faults Found:
02846 - Button for Tire Pressure Monitoring Display (E492)
008 - Implausible Signal - Intermittent
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
003 - Mechanical Failure - Intermittent
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
012 - Electrical Fault in Circuit - Intermittent
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication - Intermittent
2 Faults Found:
16670 - All-Wheel Drive
C1113 07 [008] - Mechanical Failure
16656 - Databus
U1123 00 [008] - Received Error Message
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Left_headlamp_power_output_stage:
Subsystem 1 - Part No: 1T0 941 329 B Labels: 3D0-941-329.CLB
Right_headlamp_power_output_stage:
Subsystem 2 - Part No: 1T0 941 329 B Labels: 3D0-941-329.CLB
1 Fault Found:
13705985 - Databus
17158 - Databus
Very interesting.  I've got an intermittent tyre pressure warning light, on the Yeti, that will sometimes allow it to be reset on the button and at other times won't.  No fault codes present when it's scanned,
I'd check tyre pressures, you may be resetting the tyre to a low pressure and just telling car that it is ok. Its the difference in trye rotation that triggers alert.
Don't buy cheapo sensors, they can be problematic, I speak from experience, well known named items are the way to go, they are about double the price of cheapo sensors!
I have fitted a cheapo Chinese ABS sensor to replace the OE one that failed, it was less than €2 so I bought a few, it has been fine so far.
The OE ones were way more expensive.
Granny eggs, teach to suck....😉
you must have been lucky, the cheapos i bought had very different internal resistances to the bosch one i fitted and it worked!
Sorry Schtum, Just checking.. 😉
