Start-szop battery charging
Recommended Posts
Dear community, i would like to request some guidence regarding a 2019 1.0tsi 81kw 110hp skoda rapid battery charging. The car has start-stop system. The documentation says that the negative pole should be connected to the earth point of the car, but if i’m seeing correctly it has painting on it. Should i remove something before i connect the charger to the earth point or is it ok to put it right in this painted surface?
Thank you in advance
Link to comment
Share on other sites
Yes that earth post is painted, but, I've found that as you tend to use a clip that has sharp teeth on it, clamping that to that earth post and maybe moving it around a bit, will provide a good enough connection to let you change the battery, other than that, fix the -VE clamp of the charger to the metalwork of the engine.
Edit:- I bought a used Audi earth post a few years ago, as they are plated and so don't end up getting painted, but I think that I'll need to drill out the thread in it and increase the thread size before it can get fitted to my wife's Polo - as it looks like the earth post in your picture is fixing to a bigger size of stud.
Just another job in progress!!
Edited by rum4mo
  • Thanks 1
Link to comment
Whoops, wrong thread!
 Or even wrong forum!!
Deleted.
Edited by rum4mo
deleted as this is the wrong thread I'm replying to!
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
