Dual to single mass clutch conversion.
Hamlet5
Recommended Posts
15 hours ago, sepulchrave said:
On a standard engine no benefits, only downsides.
I've often thought about this one myself for when the time comes, considering the potential savings of never having to change a flywheel again (if keeping the car "forever"), and am old enough that dual mass flywheels are a "new" thing that we managed without just fine as drivers/owners 😉
I have no prior experience with these engines, before getting our VRS.  Is it just the vibrational side-affects of losing the damping on take up of drive, I take it there are other problems that it creates with these engines/gearboxes?
Link to comment
Share on other sites
Dual-mass flywheels are a newish answer to an old problem, diesels vibrate worse than petrols because they have much stronger power strokes at low RPM, this is due to the higher compression ratio. Diesels also need stronger, and therefore heavier cranks, rods and pistons due to these very high pressures. In the old days diesel flywheels were huge to help absorb the vibrations, dual-mass flywheels were created to allow the use of a much lighter assembly which dramatically reduces parasitic power losses and inertia whilst controlling vibration, the result is a more powerful and fuel efficient engine that revs much more freely.
No-one needs a car that lasts forever because the tinworm will claim their prize long before it ever becomes relevant, fit an SMF when building a high power tuned engine, otherwise just don't do it.
  • Like 3
Link to comment
Thanks for the explanation, that makes a lot of sense.  You're right - my limited experience with diesels always involved flywheels that weighed as much as a semi-detached.  I'd never put the weight thing together, and had always assumed they were purely for the damping effect on take up 👍
Link to comment
DIY yes if you like to struggle, its worth it in the end but then again I'm built like that :)  Why dont you have a VRS clutch change party ?
Invite the right people from here and get some beers and curry in as a reward? Should all be done in about 5 hours minus the drinking :)
Link to comment
Done now thanks, not too bad a job, and yes we did drink quite a bit afterwards, sorry i forgot your invite!
  • Like 1
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
