1.0 TSI manual: difficult to pull away smoothly
What I have read they introduced an anti-stall / pull away assist in the first version of the software that increased the RPM to about 1800 rpm when the clutch pedal was lifted. It is likely that this function also closed the throttle when the car reached 10 km/h to synchronize the rpm of the motor with the speed of the car which in my car corresponds to 1100 rpm. They received a lot of criticism for this function, which made it hard to “crawl” with the car and changed the function in a later version, but it seems like they forgot to update / remove the “RPM restoration / synchronization” at 10 km/h which today makes the car hard to start in a normal way without getting a “nose dive”. It also seems like it is a general problem that affects many versions of their motors.
From a business perspective I do not understand why they do not fix this issue. For me it is an easy fix and would make many people happy with their car instead of hating it. Now they are risking losing market shares and killing their brand. Audi’s slogan is “Vorsprung durch Technik” but this software is partly a gigantic leap backwards.
I will contact Audi in Germany to see what response I get.
Well it could be my last Skoda....
On 27/10/2023 at 18:32, gogo110 said:
 Regarding the drive modes, unfortunately I don't have that specced on my model.
I've just bought Fabia 4 1.0 tsi 115hp 6 speed manual.  I haven't found driving modes on mine either. DK model.
On 30/11/2023 at 20:02, gogo110 said:
Thanks for the advice. My friend has driven the car and had no issues. Turns out it's a skill issue after all. I've been practicing adding more gas at the right moment and can now get a smooth start most of the times. It helps when you can hear the engine, the sound changes slightly throughout the process and gives you a cue when to act. I guess it'll take some more practice until it becomes muscle memory.
I'm also having trouble getting trough 1.-3. smoothly every time 🧐 I've been trying to lift clutch slower, faster, add more gas...which seems to be my best solution so far (Although I have to be careful because with my previous 69 hp i had to floor it to get going, now it makes the car fly away! My reflexes need adjustment/calibrating 😂 same with the very sensitive brake). I don't use to have this problem at all! It will take me some time to get use to, i think. *Sigh*
Hearing the engine is of my problems... I struggle hearing it because I come from a pretty noisy micro car. In the ford ka there was no doubt when to shift gears because the engine was loud and/or the car poorly isolated, and of course... 10 years with the same car.
The first couple of days I really had to rely on the Fabias gear changing guide, cause otherwise I had no clue. I rather kind of feel it than hear it at the moment. (Though I feel it's asking me to change too early around 1700-1800 maybe, and then it drops just to or below 1500, and that feels wrong and i have to change back.... Feels better to change around 2000revs or a bit above, if its correct i don't know. Never had to study the rev counter as much as now!! *Sigh*
It's getting somewhat better but today when investigating and very focused on the ACC, hence not adding gas myself, once I suddenly realized I had forgotten to change gears! I didn't even notice it 😲🥴 and it didn't warn me with sound for some reason..
Seems to be a skoda thing, glad I'm not alone, makes me feel a bit lesss "stupid" but hopefully I'll get it soon!
Edited by szilvita
  • 4 months later...
I have a Scala 2023. and I have the same issues.
is this problem solved? some people said to me There were several cylinder mods. Last time in 2024.11.01 Supposedly this can solve it.
Hello ,
No it's still the same , I'm just putting up with it tbh. How can you persuade the garage to replace something under warranty?
If I don't give gas it stalls, give gas and it throws you through the windscreen.
The odd occasion it's smooth. I hate junctions and having to go into 1st gear !
It is worth asking if there is an ECU update available for the car.
Today, I dropped off my Fabia (1.0 TSI – 110 PS, DLAA engine, 6-speed manual) for its scheduled 4-year service, even though the mileage is quite low at 35,000 km. I had noticed that, quite often, the car struggled to pull away smoothly and gently when applying a little throttle, but I didn't consider it a significant enough issue to address. So, taking the opportunity today, I mentioned it to the technician. He performed a few short test starts inside the workshop and suggested that there might be an issue with the clutch slave cylinder. He’s going to verify this, and if that is indeed the case, it will be replaced under warranty. Once I get the car back, I’ll provide an update on whether a replacement was actually necessary and if that was, in fact, the root cause of the problem.
6 hours ago, fabiamk4man said:
I picked up the car after its service. The technician confirmed that it does indeed need a new clutch slave cylinder. He claims this is the cause of the issues I’ve been experiencing when pulling away smoothly and gently. Since there wasn't enough time (it needs over 2 hours for the installation) and the part wasn't immediately in stock, I took the car back after it's service and they will notify me in the coming days once the part arrives so we can schedule an appointment for the replacement. The cost will be covered under warranty. I will provide an update on the outcome. As for the rest, the receipt shows that the service included an oil change, a new oil filter, a brake fluid change, a cabin air filter, spark plugs, and a general inspection.
Edited by fabiamk4man
I will be curious :)
Just two hours ago the clutch slave cylinder has been replaced. At the same time they replaced a small battery hidden somewhere inside the interior overhead light housing – which I didn’t even know it existed!
The technician explained that the slave cylinder had a tiny leak and would eventually fail, potentially leaving me without a clutch. However, the "issue" regarding the car’s inability to pull away smoothly and gently when using only a little throttle and low RPMs remains more or less unresolved.
As far as I can tell, the only changes I noticed after the repair are a slightly softer pedal feel (it was soft enough anyway) and a slightly different engagement/disengagement point. Otherwise, that hesitation immediately after moving off from a standstill still persists to some degree. Maybe just a little less obvious because the slight change at the engagement point drives me to a different foot reaction and different synchronization with the throttle...
The technician claims this isn't a problem and that the car behaves exactly as a brand-new one would when leaving the showroom. To me, this suggests a factory-inherent "flaw" that no service center or technician can fix. The only “solution” is to adapt my driving style—specifically how I pull away—which actually minimizes or even eliminates the issue.
So, don’t waste your time, energy, or money on something that isn't actually broken. Just adapt and live with it - simple as that… The good thing about the whole story is that I didn’t pay anything.
When I started reading this it also reminded me of the problems with the 1.5 Tsi. And I'll repeat what I've said on other forums, do the designers actually drive!
As an oldie who has driven mainly manuals but with my last three and my wife's car being DSG I'd be very interested in driving one of these flawed cars to see how I get on. I pride myself on my smooth driving and still have a manual as well, being a 12 year old Audi TT 2.0 Tsi which is a joy to drive. If it exhibited the symptons mentioned on here when pulling away I'd be extremely annoyed!
I have a 2019 65BHP MPI (normally aspirated) petrol Polo and a 2026 95BHP TSI, both with 5 speed manual gear boxes, neither have any problem on clutch release, the 2019 idles at ~ 760RPM but as soon as you press the clutch the revs increase to ~1100 and you can pull away without pressing the accelerator but it doesn't cause any problems if you do. The 2026 idles at ~ 1000RPM with no increase when you press the clutch but again no problem in pulling away without pressing the accelerator or if it is pressed, I had it back in the dealers as I thought the idling speed was and is unecessarily high but was told (presumably after check out) that this is normal operation?
22 hours ago, fabiamk4man said:
...At the same time they replaced a small battery hidden somewhere inside the interior overhead light housing – which I didn’t even know it existed!
The "small battery" will be the back-up battery for the Fabia's emergency SOS eCall system and was discussed here in February 2026.
https://www.briskoda.net/forums/topic/538090-backup-battery-trouble-code-b1916f4/
Online comments suggest an average reliable working life of 3 to 5 years and, although a new battery may be (fairly) inexpensive, to actually replace it can be a very labour intensive task as there's no standard place in cars for the battery to be located. At least from your comment, it sounds like the eCall battery in Fabia Mk4 models is reasonably accessible.
I didn’t even know this battery existed, nor what kind of battery it was. There were no symptoms or signs that anything was wrong, so I had no reason to investigate. The technicians replaced it during a scheduled service—presumably as a precautionary measure, given that the car is approaching its four-year mark. I can’t say how difficult or easy the replacement was, as I wasn’t present and was only informed about it afterward. I believe, however—though I’m not 100% certain—that they mentioned it’s located in the front overhead light console.
Now, regarding the main issue let me clarify a few points about the problem and how I perceive it…
The symptom occurs occasionally when the car starts moving from a standstill with low RPM and light throttle. Just as you’d expect the initial engagement to be complete—and as you have just released the clutch pedal—the car sometimes hesitates, which the passengers perceive as jerk. I’m not sure if this is due to the clutch itself, some poorly optimized engine mapping, or a combination of both.
The truth is, this isn’t a major issue, nor is it something that can’t be overcome by slightly adjusting how you pull away.
If, at the moment you assumed the car has started moving, you hold the clutch pedal for just a fraction of a second longer instead of releasing it completely, while simultaneously applying a tiny bit more throttle, the car will pull away just fine.
The challenge is that over the years we’ve developed an instinctive, fixed sequence of movements. It can be difficult to adapt, especially for those who frequently drive different vehicles or who only get behind the wheel of the Fabia on rare occasions.
As I mentioned earlier, replacing the clutch master cylinder helped a bit. It didn’t change the inherent behavior of the clutch or the engine, rather the slight earlier in engagement point along the pedal’s travel automatically altered the instinctive movement of the foot. Previously, the clutch engaged quite high making it feel "natural" to release the pedal entirely the moment the car began to move. Now, because there is still more pedal travel left when the car starts moving, you end up withdrawing your foot with less abruptness. In other words, the situation improves simply due to the bigger pedal travel... In fact, if you keep in mind that you should also apply a tiny bit more throttle at that specific moment, the problem is resolved completely and permanently.
I think this issue has been blown out of proportion...
Personally, while I had noticed it before, I didn't even consider it serious enough to address. I simply mentioned it as an observation to the technician during the service.
Yes, but it's a situation that has been designed in, whether intentionally or as a flaw that didn't need to be there and you shouldn't have to make adjustment to pull away smoothly. Making an adjustment is fine if you have time to do it and not under pressure.
You shouldn't need anti-stall anyway. I've driven countless cars over the years and can count the number of times I've stalled on one hand and that was usually due to having a manual choke! And I've rarely been with other drivers who have stalled either. Sounds like another of those solutions where none was needed and is more hindrance than help.
Oh my god, I thought I was going crazy.
This entire thread healed me but at same time made me mad as I now see this is a factory feature.
I was really hoping there was somebody saying "the fix is just a ECU update, or a part replacement". My hope died.
I didn't even knew the clutch had problem that needed fixing to begin with.
This feature made me so mad I just hate the car at this point. I really do. The clutch and the engine feel like they live in different postal codes.
To the people that say "it's just a question of driving it differently", didn't Steve Jobs say "Your holding you phone wrong" whe one of his phones was losing service when you held it differently than usual?
