rear shock setup
Hi guys
just replaced both rear shocks with monroe
and would love to know what height should wheel be to tighten bottom bolt
thanks in advance
04tony
dublin
Fully loaded neutral position.
Place the jack under the rear arm until the wheel lifts off the ground. This is in its loaded neutral.
Thank you sir
i thought there is a measurement from wheel arch to center of hub
42 minutes ago, 04tony said:
Thank you sir
Can't do it that way due to what you may have in the boot.
