Fabia MK1 starter solenoid plug
My son's 2005 Fabia 1.2 HTP developed an intermittent starting problem (no crank, no error lights). I found the wire on the starter solenoid had broken inside the insulation (apparently a common problem).
On inspection the wire was very stiff and corroded near the plug. I cut it back and extended with new wire and fitted a spade terminal which cured the problem for now at least.
However, I am concerned that this will vibrate loose over time as there is no locking mechanism.
The OE plug had a spring clip and rubber seals to prevent water ingress. pictured below
Can anyone tell me where I can buy a new plug, or how I can remove the metal crimp from the plug to rewire it?
image.png.fba0778d109ce3a0d1d793adb8166f7f.pngimage.png.053c6be2c29ac3a3d2f100421b94cf2f.pngimage.png.8440ce332856c27f429da9472ac91c49.png
Thanks @Breezy_Pete - certainly looks like it!
