Upgrade oil cooler
On 03/05/2024 at 23:43, Jimbray said:
I have the same problem - Mine is a 150 front wheel drive. It's fine until towing uphill, the temps fly up.
I know you can get the conversion but no one seems to want to tell me the parts needed. Front dual fan is one.
Have you had any success yet?
I have installed this: https://www.darksidedevelopments.co.uk/products/darkside-front-mounted-engine-oil-cooler-kit-for-2-0-tdi-mk7-platform-engines.html
Without towing oil temp. approximately 10C lower.
On 28/12/2023 at 22:23, Bap33 said:
If you have an OEM first mount tow bar, then your Superb is fitted with a dual fan to vent the coolant radiator.
This can be checked easily. 😉
BTW, do they both blow when necessary?
A fan failure could also be a cause of your high temps… 🤔
Both blow 😊
On 29/12/2023 at 05:03, IulianE said:
I think the engine is pushed by the remap way over and adding a caravan is killing it.
Reputable tunner in my country said to me there is little room to remap this engine (wich I also have) safely and reliable.
His advice was for best reliability was:"don't do it" or max 205 HP if you really want
I have heard many opinions on this from many experts. I guess it does affect temp. However 98% of driving no issues. I have now fitted external cooler. Temp 10C lower. Hope this will do the trick.
Interesting, mine is a 2020 2.0D DSRA (evo) engine (just 150hp) with factory ordered/fitted towbar and the rad just has a single fan - another little change on certain newer motors?
Edited by Shuggyboatsuperb
Hi - I posted this a day ago - seems I am in the same boat - did you ever get it resolved? thanks - Alex
Hi - my Octavia 2.0 tdi (remap to 190) dsg auto estate 2014 70k seems to struggle towing my 1100kg caravan. Any slight incline @ 57 mph puts the oil temp up to 140+. The coolant remains rock solid, and on the level the oil temp towing is around 130. Non towing its around 115.
I have had the intercooler changed, gearbox oil changed, also the oil temp sensor, but am lost as to why it seems to be running so hot when under load. Is this normal is my question? If not - any suggestions please
I have towed two differed caravans with it, so know that the caravan weight is around the 1100kg - yesterday it was 5c outside and still managed to hit 143C on the m4 at 57mph - not even a big incline
So, I got the double fan and added it. Made a world of difference. Don't get me wrong, the oil temp still goes up a little, but not as much. Dead easy to change! I think mine came off an Audi A3 and fitted in 15min.
Thank you - Sounds like a relatively low cost option to start? Do you remember which year / model A3 fits please?
I just got part number - 3Q0121205. If you ebay this loads come up! My car is a 2018 150tdi but they should be the same.
thank you )
Did you change the oil cooler too?
  • 5 months later...
a quick update - twin fan fitted, and this reduces the temperature of the oil very quickly when it hits 140C and I idle the car. Still having oil heat issues though. I have changed all sensors, heat exchanger etc, and am now thinking its the car that simply cannot cope with towing the caravan - even if it is below the maximum permissible weight stated. Water temp remains perfect still. Somewhat disappointed in the towing ability, and frustrated as to how to solve it now!
It would appear to me that you need an upgraded oil cooler with thermostatic control to prevent overcooling on lighter loads.
Others have suggested an upgraded radiator too from a 190 model. Does anyone know if thats a straight purchase and fit to my mk3 150 tdi please?
Well I upgraded the radiator to to the higher core 190 model.
It's still crap - overheating both oil and water on incline - even at 65 kmh.
Towing van is 1300 max Inc stuff in it.
Not impressed.
On 29/12/2023 at 17:56, Lykkegaard76 said:
In my opinion 225hp for a 2.0 is not crazy power,
It is a bit compared to older less highly strung (read less overfueled) engines.
I have a 4.2L diesel that does 130hp...but can pull Christ off the Cross all day long and not overheat.
All about fuel delivery. Tune for more hp = more fuel = more heat. Needs bigger radiator and oil cooler.
It's a small engine. De rate the power (remove tune) and it will probably be fine
It wasn't before I uprated it. Back to the drawing board, as I still feel something isn't working correctly
How does the car behave when "not" towing? Even if you give it full throttle and drive more aggressively? Also, what oil are you using?
I forgot if you mentioned, how old is the car and mileage? Water pump failing perhaps?
I am just throwing all cards on the table, there is no way the cooling system can't cope if in proper condition ...
Would that be a 1HZ? 😊
Ha ha
Yep
Kinda lazy motor but it never overheats and it pulls a heap all day long of I ask it to
A true honest beast of a bygone era.
I had to take the decision to part with the 78 as I failed to materialize my plans to travel around .... but I really liked it.
Also very accommodating to work on ... everything straightforward.
You might not need, but I do have workshop manuals and such (electronic), I can share if you want ☺️
That would be great
Very much appreciated
Sent a PM
