👋 How to cut power to the cigarette lighter when the car turns off?
Happy new year! I need to know, how to cut power to the cigarette lighter
Fit a relay in series with the feed wire to it, with relay coil powered by an ignition switched 12V.
Exactly what I would do.
I don't think it is a cigarette lighter, it is a 12v power socket nowadays,
designed to allow use when in the car, so unless leave something plugged in to operate when not there, no point in switching it.
Pedantry aside I think you have completely misunderstood the request of the OP.
I recently installed a dash cam that is cigarette lighter powered, it just records without interruption even after the car is turned off. I know there is a dash cam kit that plugs into the fuse box, but I prefer to modify the car cigarette lighter if anyone has!
Use a relay, very simple to achieve what you require.
You can run the dascam from one of the usb c sockets. These turn off when the igniton is off. You may find that the dashcam thinks it is plugged into a computer, so you may need a data blocking cable I got 3 usb c to usb a data blockers from Amazon.
12 hours ago, wokwon said:
Look at the fuse box behind the glove compartment..  The fuse for the lighter circuits (can't remember the number).  You'll see this fuse holder position is slightly different than the nearby ones, there is a 2nd position where you can move it halfway down.  The lower position will make the sockets switched (terminal 15), the upper position is always on (terminal 30).
You speak of lighter circuits, does this apply to the accessory socket in the luggage area? IE are both on the same fused circuit?
This would have been a better solution to the increased standby battery drain from my towing relay powered from the boot socket than the switch I installed which has brought problems of its own.
Your explanation was an excellent one by the way, I had read of this before, about a lower fuse position but your mention of "halfway down" and the description of the two supply circuits made it all make sense 💡
I don't think the OP's 2018 Kodiaq has USB C sockets.
