Škoda Favorit 1.9 TDI
Recommended Posts
I've stumbled on this. Here is something new.
The setup may output 200nm + of torque. It might surpass 1.8T conversions by torque output.
What do you think?
  • Like 1
Link to comment
Share on other sites
 The weakest stock 1.8T has 210Nm of torque, which is same as stock TDI. I don't see a point of this conversion, heavier, weaker, same effort to get it in.
If they used a more modern PD unit, it'd be a different story
  • Like 1
Link to comment
8 minutes ago, R_Blue said:
How about this one?
320Nm @ 1900rpm 😱
110kW ARL - that's one of PD engines I mentioned. Similar engine was used in Fabia RS.
I can't recognize which engine they used but, can Favorit handle that much torque?
The engine is an early TDI with rotary injection pump, used in MK3/MK4 golf. Those had 210-235Nm.
They swapped the gearbox, too, the weakest points are now driveshafts and car's body itself.
Edited by Papez
  • Thanks 1
Link to comment
So if it was a PD engine it could end up like: (Not because of  those crashes but x3.2 of designed torque) 😀
But, it's good to see Favorits are still getting some attention for engine swaps. I hope the author on youtube completes their project and posts more videos about it.
Link to comment
The overall power is same or lower as 1.8T conversions, so it's not any worse than that 😃
  • Like 1
Link to comment
On 20/02/2024 at 20:47, ChinaBoyZ31 said:
How they put the 1.9tdi VP gear box? What the mount need to use for the felicia pickup?
I'd like to know that too.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
