Part number needed if possible
The car is a 2020 Superb Hatch,  SE. The part I'm looking for is a light, I believe.
It's not there so I don't know what it should be!
At the back of the arm rest box,  not the best description, or central console I have a hole.  Approx 25mm x 10mm (might be bigger/smaller), I'm going on memory here, should this be a light and if so does anyone have the part number.
Many thanks.
sounds like u r referring to either the additional USB port, or light.
the USB port is not standard, and usually there is a blanking plate there if its not factory fitted.
Thanks,  I am now wondering if it's a usb port that has been pushed too hard and has 'disappeared' into the void behind.  There is definitely some wiring inside the 'hole'.
Can't wait to get my hands on it to play......ATM it's parked up at my Mum's as the Volvo is still on the drive and full of my fuel,  so guess what I'm driving hard until it goes back to the company?
Seems strange that there may be an additional usb (assuming that's what it is) on the SE but I was surprised to find the car had ACC and full LED headlights so who knows.
Car is ex mobility so maybe the last owner added a few extras.
Thank for your help.
Mine is also a 2020 SE and came with a USB port there as standard.
 (Handy for plugging a phone charging wire, while music memory stick in the front USB port)
I have this.....
On a different  note reading the forum has sorted my rear map lights out.  In/out for on/off????
Working now!
Just the mystery of the hole!
have you blanking plate or empty hole?
to save few cents, Škoda decided users don't need it anymore
pictures from MY23 L&K
-> https://www.briskoda.net/forums/topic/510961-2023-280ps-lk-replaced-2016-220ps-style/?do=findComment&comment=5740237
part codes, which I haven't installed and probably won't install it either
3V0 919 390 B 2
19€   https://www.skoda-parts.com/spare-part/3v0919390b-storage-compartment-lamp-skoda-44271.html
connector
4B0 971 832
https://www.aliexpress.com/item/1005001570915276.html
8W0 971 832
https://www.aliexpress.com/item/1005003523561834.html
I'll have a closer look on the weekend and see if I can fish the cables out but there is just a hole atm. I'm an electrical engineer but trade so quite happy an long as things don't need coding.
Cheers for the part numbers.
I managed to fish this out.
Guess I'm buying a new light.  Even though it wasn't on,  it appears to test OK... let's face it is not exactly complicated. Tested on the multi meter and we have continuity through from leg 1 to resistor. Resistor reads correctly,  so from pin to one side of led all appears correct.  The other side of the cree goes to leg 2 so circuit is complete.  Using meter on capacitor test the led does light so again appears unit is working..
So, why isn't it on??
I've read a thread on here stating this should be on all the time,  is this correct or has the cat messed up my light?
I've stripped a usb lead and powered the unit and it works,  not sure if it's supposed to be 12v powered but 5v dc gives me some light.... roll on the weekend and I grt to play with the car.
So refitted the unit and tested. It lights when the ignition is on.... more to rebuild something like a light.... watch this space.
Update below.
It works!
Now to find some other stuff to do! Got the dash cam to go in but it was peeing down on Saturday. I did notice, no fuse for the rear wiper,  not surprising as there is no wiper but didn't get as far as testing it...
Bloody weather!!
Put the 16inch space saver in the boot, so that needs checking on the car but it seems OK,  after placing it carefully against the existing 17" on the car.
Edited by Fatfred
Additional info
