Octavia VRS MK1 A/C pressure sensor location
Any Octavia vrs mk1 owners know the exact location of the air con pressure sensor?
I haven’t had air con for a few years , but recently got it gassed and then still none.
Running vcds it found the air con pressure sensor code showing.
Ive purchase a switch and then I began to fit, what I thought was the pressure sensor. Either I’m in the wrong place or the new part is wrong.
On the air con compressor there’s a pipe coming of that has a sensor with electrical plug. I thought this was it but the new part is slightly smaller and has three electrical outlets whereas the original, or what I thought was it, has two.
googling the part number , I believe I do have the right part, so I’m probably looking in the wrong place!
any ideas??? TIA
Edited by Ade3277
Can you message me with your VIN, or just post it here?
from what I remember its on the bulkhead, turbo inlet pipe area.
Have a look in here, air con' is in Section 87 Page 50, I think its item 2.
Note the picture shows a L/H drive car so its on the opposite side :-
Octavia Vrs Air conditioning.pdf
Edited by Silver Bullet
  • 2 years later...
Did you find your air con pressure sensor as I am looking for mine at themoment
Recently Browsing 1
