flashing coil light
Hi i have recently bought a 1.6 MK2 fabia monte carlo and the glow plug light has started flashing putting the car into limp mode your can turn the car off and back on which solves the issue sometimes but the eml light will sometimes come. on when you plug in to the obd11 port it says boost pressure sensor low i have tried a few things to try and sort it like
using a dpf cleaner in the fuel
using another dpf cleaner sprayed into the dpf and towards the turbo
i have checked the turbo actuator which still seems to be working fine as it still holds a vacuum
any ideas what could be the issue as i am stumped
@Kcook Any chance of you posting actual diagnostics rather than just "light sometimes comes on"?
code has been cleared will need to wait for it to come back on as i dint have it to hand
the code that is coming up is p0237 turbocharger boost sensor A circuit low
The turbo actuator on the 1.6 TDI is electronic so I'm not sure what you're testing but they often give trouble and have to be replaced and re-adapted.
everywhere I’ve looked says if it holds a vacuum it’s not that that’s the issue so not sure if it is that
Cheers for the help turns out it was the map sensor the cables had snapped to to the vibrations coming from the engine
