Columbus head unit issues.
Hi all, just recently happened that my head unit for my skoda superb has started behaving weirdly, its stuck in German and when I try and change the language back it just freezes on loading the language, also the Bluetooth and radio has stopped working, any advice on a good replacement unit for this particular type of car that would work with all the features like parking sensors and steering wheel buttons etc?
No need to replace, try to reflash it. What is the current software version?
Okay I think it's version 4024
Hi! I have the same issue. Did you manage to solve it, and how? 😊 I have tried to reset mine without luck.
No not yet, waiting to hear back from pab546 but will try updating with a disc I found in the car that I believe is a software update.
Pab546 is the right man for the info.
Helped many people with this very common issue.
Fixed this issue now! I followed this tutorial: https://paulroberts69.wordpress.com/2015/10/01/upgrading-firmware-and-maps-on-vw-rns-510-satnav/
The link to updated software:
https://drive.google.com/file/d/1sHpwduaniYoosbBgt3-4BmMy2LfvJpGG/view
I basically burned the iso file from the second link on to a cd (you'll need some software to burn the file to the disc) then with the key out the ignition just pop the disc in and after waiting a bit it should show a message and instructions, it might be worth checking versions etc but tbh I couldn't actually find any other links for other software apart from this version.
Edited by LukeG99
Thanks for the guide. I’ll see if it can help me. My issue is that I put the software CD in the slot but it is not reading it. CD is kind of just rattling in there now and won’t even come out…
Ive had this issue before and got a disk from Ebay to update it. Quite the doddle.
The link is no longer valid and I can’t also find greenbell14
