glovebox light fuse?
Hey all,
My glovebox light has never worked, I never explored it until I changed the pollen filter recently and noticed one of the wires was cut. After temporarily rejoining it and testing, it still didnt work. I tried a known working bulb and light unit from the boot and this didnt work either so I suspect the fuse has gone. Its likely to be a mini fuse but as everything else appears to be working, I am guessing its on its own fuse. Can someome tell me which one it is and which fusebox location?
Thanks,
Doug
  • Sponsor
If main, front interior light is working, it's not a fuse issue.
Both fed directly from BCM.
The switch, with red/white and brown wires may be the issue instead.
Thanks Pete, the front interior lights work fine, thats frustrating. How far back is the switch wiring? I didnt have a good look tbh as I didnt have alot of time when I looked at it but will take it all apart when I can. I didnt see anything else obvious in terms of damage and I can only assume the damage has been caused by someone changing the pollen filter before.
  • Sponsor
No idea, sorry, just going off wiring diagram.
