How to update swing radio….
My swing radio needs to be updated since there is a problem with apple CarPlay.
How can I do this without going to the dealership?
see picture for the current old software version… it’s now 8742 and should be at least 8755 or even newer perhaps…
Thanks for helping me out in advance!!
Note; the update button says there is no update available;
So I guess i have to put an usb stick with an update file in the usb connection??
Edited by Jeroen1981
Link to 8755 sent on PM.
What is your CarPlay problem?
Thanks for the link!
The problem is there is a disturbing sound after a while… if you press pause it’s gone for a while but it always comes back
Update succeeded! Thanks!!! 😊
@pab567 Do you maybe also know how to get the radio logos in? There all empty!
Just re-save the stations and they should appear again
They don’t 🤨 Any tips how to solve???
Thanks in advance!
If your swing is similar to the early version I have, the station logos are loaded individually from SD card:
Station logos
The station key of a preferred station can contain the name and the station logo.
Assign a station logo
› Tap on the Radio function surface  → Station logos.
› Tap on an occupied station button and select the data carrier (SD card, USB).
› Search for and select the desired station logo on the respective data carrier.
Remove station logo
› Tap on the station button from which you want to remove a logo.
› or: Tap on the function  All to delete the logos of all the station buttons simultaneously.
› Confirm / cancel the removal.
It's slow and tedious process.
Attached is an old UK specific file.
You can probably download a current file here:
How to add radio station logos to your VW or Skoda radio (media.info)
or even VW or Skoda may have them somewhere.
GBR_20200331.zip
  • 9 months later...
@pab567 Would you be able to send me the firmware link as well ? I also have a problem with CarPlay, where the microphone does not work while making a phone call (but it does work when using siri or when i turn down the volume to 0. I am currently on version 8740.
@RichCz check your PM
Hi there, I have a Swing in Octavia 3. I can not connect to 37 Navi in VCDS. I would like to activate a rear camera there. Can i make an update / change firmware in that radio?
@pab567 Can you please share the link, I hd the same issue. Thanks in advance.! :) I am currently on version 8740.
Edited by LuisMla
Address 37 was valid for PQ based cars, e.g. Octavia 2, for Octavia 3 you can connect only to 5F (Infotainment) and Swing has no built-in navigation and as far as I remember does NOT support RVC. Pls share part number or VIN to check.
Link to download MEN2_EU_SKGPx_P0080L_8755 sent in PM
thanks
downloaded !
Have it helped to solve the issues with carplay?
I have 8755 now and the issue is still there :(
  • 3 months later...
Hi could u send me it please i am trying to update my skoda fabia 2018 and apple carplay keeps making static sounds
@pab567 please could u help me i need the file
Part number and SW version of your unit?
hi mate my software is on men2_eu_skgpx_p7381l
  • 11 months later...
