MOT Question
My Furby was first registered in Mid July 2003 (15th I think) and not having had to MOT a "new" car before :rolleyes: my question is when do I need to get it's first MOT ??
When I renew insurance in September?
Before I tax it in August?
Or anytime now? :confused:
Needs to be done for the same date as it was registered but 3 years later...
Cheers Mate :thumbup:
I'll get the pennies out then :rolleyes:
If it fails on anything I'll be very surprised. One note though - turn the headlight dip adjuster to the highest. Mine only failed on that on its first time out (if you keep it down on "3" like I usually do)
So it should cost you around £30-£45 depending where you go. :)
I paid £44.15 which ties in with the following site....
http://www.ukmot.com/MOT_prices.asp
Usual failings on a newish car will be bulbs and headlight alignment, neither of which are going to break the bank :D All my modded diesels have also sailed through the emissions test :D
Chris
Here's a tip for you, get it done a few weeks before its 3 years old. That way if it fails its still under warrenty and you can get it fixed for free. ;) (as long as the fault is covered of course) :cool:
I get mine done for £15 ;)
You should get a notification in the post of the first MOT IIRC
take your V5 documents with you if you get it done much before the 3 years are up , that way the test station will have proof of the date of registration :thumbup:
:rolleyes: Most cars coming up for their first MOT are already on the computer system.... Thats the good thing about the new test, it will tell you first reg; date and also add any time on if you have the test done within a month of its expirey
Phil
