Check Rear Reversing Light message
Hi. Every time I put the car (it's a hatchback not the estate) in reverse I get a yellow bulb warning on the dash come on and a message saying "check right reversing light".
The right reversing light (and fog lamp) are both working fine - they're on the inner small cluster. They're LEDs rather than bulbs.
I wonder if it might be that the message is just incorrect and the fault is really with the left inner cluster - neither reversing or fog lights come on on the left, but then I can't remember whether the car only has reversing & fog lights on the left,
Could someone confirm whether the reversing and / or fog lights should be working on the left, and whether there's a known fault with the error coming up for the wrong side?
Cheers
Hello, welcome to the forum.
Are the LEDs a recent change - or are they OEM? Replacement, after market LEDs can often cause issues with lamp monitoring systems. UK vehicles are commonly not fitted with two reversing lights - or rear fog light on LH side.
Hi and thanks for the welcome.
As far as I'm aware they are OEM. I've had the car 7 years and never been a problem til now.
IIRC, the rear lamps aren't difficult to access from inside the trunk - if you can, try removing the indicated bulb and check the contacts on connector and bulb - is is possible that dirty contacts have created enough increased resistance to trigger the lamp fault even though the lamp is working.
OK thanks, will do.
My sums and your metadata say the car is 9 years old, so someone else would have owned it first.
