speakers
Hi,
Both front door speakers are making a buzzing/farting sound.  Before I get new cones, can I check that it is likely to be new speakers that is needed rather than another cause?
Thanks,
Mark
Anyone?
Would it be worth doing a full reset of the head unit before swapping out parts?
Or a VCDS scan?
Someone else recently had the same issue, it was the plastic behind the speakers which broke
Pretty sure he reckoned it could be caused by the doors closing and over the years just broke
if i were you I’d remove one door panel and speaker and investigate, if its had it then get new ones, if they’re fine then not sure
Thanks all, really helpful
Speaker needs drilled out to inspect and riveted back into place when refitting.
