Canbus
I have installed Canbus with the version vw-rz-08-0030-b1 with Andriod unit (K2501 T5)
I can't get a car error on it
I can BTW read trip setting
any support with it?
Edited by Mazen86
No you haven't; CANBus is a manufacturer level engineering decision.
You realise the OP is from Egypt? English probably isn't their first language and that's probably not what they meant?
vw-rz-08-0030-b1 appears to be some sort of Canbus interface and K2501 T5 an Android headunit. I can't help solving the OP's problem but I'm guessing they're trying to get car diagnostic data on the headunit.
@Mazen86 You might find more help on the XDA thread I've linked above. It's 121 pages long though...
Edited by HappySam
What do you mean by manufacturer level engineering decision?
I don't get OP part? What di U mean?
Yes this what i want (get car diagnostic data on the headunit)
OP means original poster, I.e. @Mazen86.
The other reply regarding engineering level decision - is not helpful to resolving your issue.
So, to try and clarify - you installed a new Canbus module to display diagnostic data on the in car infotainment screen?
Yes
Ok, do first things first, the Android head unit is a bad route to take. I have been there and back.
The canbus module they provide will give you limited actions.
Basically it will display parking sensors, reverse cam, let you choose the driving mode (and sometimes display it on the screens), let you retain steering wheel control and.... That is about it.
You will not have any car diag reading.
I tried several units from different brands and they all work the same way.
Did you try use OBD 2 by Bluetooth to get car Diag on android head unit?
I use a Bluetooth odbê scanner on my Android phone that works.
Most of these Android head units do not allow you to use the Bluetooth odb2 reader on theme.
The problem is original unit very limited features and mine need replacement
New unit expensive so I think about move to canbus and try
I thought the same, wasted money on android units then went for the mib update. Worth every penny. You keep all the car features, oddly minus footwell light management. But all the reste is heer plus AA and CP.
Most important good phone call quality. On the android units, phone calls are impossible because it is so bad
Where you get mib online or local?
I got mine from @pab567
Send him yoir vin number by pm and he will fix you right
