Enabling TSR Oct 3 VRS diesel.
Anyone managed to get this working on a facelift car?
I've followed several guides and end up with a maxi dot message saying dynamic road sign error.
And it doesn't work, from what I can't tell this is something to do with the road information from the sat nav not being available or being able to be read.
I have the A5 camera and it's 3Q0 starting I have the Amundsen standard sat nav I think.
Is it a Multimedia issue or something else?
Any ideas?
Should work fine on that age and camera.
Can you add an autoscan along with an adaption map from 5F.
It might also be worth saying which guide you're using...
That was the guide I was using, I assume you mean a full log and you want the 5F adaption screenshots?
Adaptation
    Control unit: 5F Multimedia
    Values:
        traffic_sign_recognition_0x21_msg_bus:
            Old value: Databus extended
            New value: Comfort data bus
    Mileage: 105061 km
    Date: 2024-07-13 21:08
Adaptation
    Values:
        MFL_msg_bus:
    Mileage: 105061 km
    Date: 2024-07-13 21:07
Long coding
    Old value:
        03735101FF00000051111201008800002F0209C6012005008F
    New value:
        03735101FF00000051111201008800002F0209C601200500CF
    Mileage: 105061 km
    Date: 2024-07-13 21:03
Long coding
    Control unit: A5 Driver Assistance
    Old value:
        0203070100000401000213408150A81084000E200000
    New value:
        0203070100000401000213408150A81094000E200000
    Mileage: 105061 km
    Date: 2024-07-13 21:01
Adaptation
    Values:
        menu_display_road_sign_identification:
            Old value: activated
            New value: Not activated
    Mileage: 105061 km
    Date: 2024-07-13 21:00
Adaptation
    Values:
        traffic_sign_recognition_0x21:
    Mileage: 105061 km
    Date: 2024-07-13 20:59
Long coding
    Control unit: 17 Dashboard
    Old value:
        27A5010069848600010A6B021001000000000000
    New value:
        27A5010069808600010A6B021001000000000000
    Mileage: 105061 km
    Date: 2024-07-13 20:57
I believe they were the adaptions I configured or do you need the full history? As its very long winded otherwise?
All control units listed ignore any errors as I have resolved one or 2 I caused and only have 3 error codes now, LED bulbs under seat, key battery and DAN aerial are the only 3 error codes.
Full scan
    Control Units: 18
    Fault count: 5
    Control Units:
        D7 LED Module Right
        System description: LED1R
        Software number: 7P5941591AJ
        Software version: 0011
        Hardware number: 7P5941591A
        Hardware version: H07
        ODX name: EV_LED_PLUS_R_KEBODAVW416
        ODX version: 001003
        Faults:
                No trouble codes found
        D6 LED Module Left
        System description: LED1L
        ODX name: EV_LED_PLUS_L_KEBODAVW416
        ODX version: 001003
        Faults:
        A9 Structure Borne Sound
        System description: SAS-GEN 2
        Software number: 5E0907159
        Software version: 0001
        Hardware number: 4H0907159A
        Hardware version: H06
        Serial number: 170908200290
        ODX name: EV_SoundActuaGen2AU64X
        ODX version: 003010
        Faults:
        System description: MQB_B_MFK
        Software number: 3QD980654
        Software version: 1272
        Hardware number: 3Q0980654A
        Hardware version: H08
        Serial number: 02091741K20063
        ODX name: EV_MFKBoschMQBB
        ODX version: 001001
        Faults:
        76 Parking Assistance
        System description: PDC 4 Kanal
        Software number: 5QA919283B
        Software version: 0044
        Hardware number: 5QA919283
        Serial number: 00030841961727505221
        ODX name: EV_EPHVA14AU3700000
        ODX version: 009033
        Faults:
        5F Multimedia
        System description: MU-S-ND-ER
        Software number: 5Q0035874C
        Software version: 0468
        Hardware number: 5Q0035874C
        Hardware version: H41
        Serial number: SKZAZ2T5391491
        ODX name: EV_MUStd4CTSAT
        ODX version: 001022
        Faults:
                U111100 - Function limitation due to missing message
                    static
                        Date: 2024-07-13 14:02:20
                        Mileage: 105039 km
                        Priority: 6
                        Malfunction frequency counter: 1
                        Unlearning counter: 138
                        Dynamic environmental data: 028677184402
        52 Passenger Door
        System description: TSG BFS
        Software number: 5Q4959392E
        Software version: 0032
        Hardware number: 5Q4959392B
        Hardware version: 011
        Serial number: 0000280067036
        ODX name: EV_DCUPasseSideEWMAXCONT
        ODX version: 006001
        Faults:
        4B Multifunction Module
        System description: FCM MQB Low
        Software number: 3Q0907338
        Software version: 0286
        Hardware number: 3Q0907338
        Hardware version: 002
        Serial number: 29091710520539
        ODX name: EV_MultiModulContiVW48X
        ODX version: 001010
        Faults:
        44 Steering Assistance
        System description: EPS_MQB_ZFLS
        Software number: 3Q0909144K
        Software version: 5072
        Hardware number: 3Q0909144H
        Hardware version: 506
        ODX name: EV_SteerAssisMQB
        ODX version: 013144
        Faults:
        42 Driver Door
        System description: TSG FS
        Software number: 5Q4959393E
        Hardware number: 5Q4959393B
        Serial number: 0000280241683
        ODX name: EV_DCUDriveSideEWMAXCONT
        ODX version: 006001
        Faults:
        19 Gateway
        System description: GW MQB High
        Software number: 3Q0907530G
        Software version: 4304
        Hardware number: 3Q0907530C
        Hardware version: 436
        Serial number: 0006870215
        ODX name: EV_GatewNF
        ODX version: 013023
        Faults:
        17 Dashboard
        System description: KOMBI
        Software number: 5E0920957E
        Software version: 0310
        Hardware number: 5E0920957E
        Hardware version: 303
        ODX name: EV_DashBoardVDDMQBAB
        ODX version: 009060
        Faults:
                U111000 - Function restriction due to communication interruption
                    static
                        Date: 2024-07-13 14:08:12
                        Mileage: 105039 km
                        Priority: 6
        16 Steering Column
        System description: Lenks. Modul
        Software number: 5Q0953507GD
        Software version: 0140
        Hardware number: 5Q0953549F
        Hardware version: 003
        Serial number: 05101708490881
        ODX name: EV_SMLSKLOMQB
        ODX version: 020002
        Faults:
        15 Airbag
        System description: Airbag VW21
        Software number: 3Q0959655BH
        Software version: 0703
        Hardware number: 3Q0959655BH
        Hardware version: 006
        Serial number: 003W4PJLV0KQ
        ODX name: EV_AirbaVW21TS6VW48X
        ODX version: 001014
        Faults:
        09 Central Electrics
        System description: BCM MQBAB H
        Software number: 5Q0937084CQ
        Software version: 0253
        Hardware number: 5Q0937084CG
        Hardware version: H36
        Serial number: 01001726802254
        ODX name: EV_BCMMQB
        ODX version: 018001
        Faults:
                B11FF01 - Footwell lighting Electrical error
                    static
                        Date: 2024-07-13 13:36:20
                        Mileage: 105039 km
                        Priority: 6
                        Terminal 15 status: On
                        Terminal 50 status: Off
                        Voltage: 12.0 V
                        Outside air temperature: 18.5 °C
                        Status Bremslichtschalter (HW): Off
                        Status Bremslichtschalter (CAN): Off
                        Off: not activated
                        Parking light: not activated
                        Automatic high beam assist: operated
                        Low beam: not activated
                        Parking light left: not activated
                        Parking light right: not activated
                        Letzte Weckursache/ Werte [00;2E]: keine Störschutzursache
                        CAN-Bus_aktiv: On
        08 Air Conditioning
        System description: Climatronic
        Software number: 5E0907044AP
        Software version: 2001
        Hardware number: 5E0907044AP
        Hardware version: H04
        ODX name: EV_ACClimaBHBVW37X
        ODX version: 006146
        Faults:
        03 Brakes
        System description: ESC
        Software number: 5Q0614517AQ
        Software version: 0400
        Hardware number: 5Q0614517AF
        Hardware version: H62
        Serial number: 62817000002382
        ODX name: EV_Brake1UDSContiMK100ESP
        ODX version: 036010
        Faults:
                P164700 - Checking coding/versions of control modules in drivetrain
                    static
                        Date: 2024-07-13 13:41:56
                        Mileage: 105039 km
                        Priority: 3
                        Malfunction frequency counter: 2
                        Extended Freeze Frames: 0000001A32000000A8000100FD01000000000000000000
        01 Engine
        System description: R4 2.0l TDI
        Software number: 04L906026BR
        Software version: 7724
        Hardware number: 04L907309R
        Hardware version: H24
        ODX name: EV_ECM20TDI01104L906026BR
        ODX version: 004006
        Faults:
                U112300 - Databus error value received
                    static
                        Mileage: 105039 km
                        Priority: 6
                        Unlearning counter: 255
                        Engine speed: 0.00 1/min
                        Normed load value: 0.0 %
                        Vehicle speed: 0 km/h
                        Coolant temperature: 57 °C
                        Intake air temperature: 57 °C
                        Ambient air pressure: 990 mbar
                        Voltage terminal 30: 12.020 V
                        Dynamic environmental data: 20962817E0000017DD1117DE000011870000
My car has lane assist, no satnav
Traffic Sign Assist Activation
1. Control Unit 5F - Information
Adaptation
Car_Function_List_BAP_Gen2
traffic_sign_recognition_0x21 = Activated, then Green tick
Car_Function_Adaptions_Gen2
menu_display_road_sign_identification = Activated, then Green tick
8. Control unit A5 (front / advance camera)
Security access - 20103
Control unit Long Coding
Byte 16
Bit 04 Activate , then Green tick
13. Control unit 17 (Dashboard)
Byte 5
 Bit 02 Activate, then Green tick
I also tried this guide from OBD11 forum from memory.
This guide was on YouTube supposedly for all MQB platform cars.
Tried this guide on here?
Huh that has worked this time although I can't find that channel 151 menu display threshold adaptation for some reason. Not sure what difference that will make. Just been out and it's shows road signs and changes and tells me if I exceed the speed limit into one.
Search for the adaptation channel by name, newer versions with UDS protocol no longer use simple channel numbers.
Bear in mind I'm using OBD11 not VCDS,
Controller A5 (Front / front view camera)
16 - Security Access - enter 20103
10 - Adaptations
Select channel Display end of speed limit symbol
Change to activated
Actually it is that I'm struggling to find sorry got a little muddled up there as to what I couldn't find.
If I go into adaptions after entering the security code I don't have anything that resembles that.
I have noticed on a few 30mph roads it says the speed limit is 60mph and does drop back to 30mph after a while it also shows it as 60 on the factory nav, it also shows a lot of 30mph limits as 20mph as well.
 I suspect to update the nav mapping id need a newer version on an SD card?
Updated maps can help to get the TSR display more accurate since when it can't read a speed limit sign it defaults to using map data - but then if the map data is wrong...
I've noticed it seems to default to 20 (incorrectly) on several roads near me that are actually 30, that's even with the newest Amundsen MIB2 maps.
It seems from some googling that menu is not available on all cameras so seems to be camera dependant possibly. I googled it and found a thread saying that. Cause in adaptions on OBD11 I have nothing like that.
Well I downloaded the 2024/25 map data for the inbuilt sat nav but I use Waze or Google maps on android auto mostly anyway. But thought it was worth updating it for the speed limit info.
Would help if the instruction on the sat nav portal actually told you exactly how to do it, but use the original SD card, save the contents off the card just in case, download the correct mapping by checking the version on the car first, unzip the files you download with 7 zip or any zip program. Copy the maps folder to the SD card and the checksum file and then pop the card back into the card and hey Presto. Oh and format it fat32 or exact dependant upon the size of the card.
Have not been out to see if it's solves some of the errors on speed limits yet though. But don't expect much hope.
