Skoda Swing Firmware Update - MU 8755
Nope. :( I've got the same issue. Just have to live with it.
  • Replies 95
  • Views 12.6k
  • Sent on PM
  • PM
  • General rule I recommend to follow is "If it works without any issues don't touch it" which means don't make a firmware upgrade if everything works ok. Bricking th eunit during firmware upgrade is not
On 19/07/2024 at 23:56, pab567 said:
Sent on PM
Hello,
can you please send me the file also? thank you🙏🙏🙏
Sent in PM
Hi everyone,
I bought a Fabia from 2020 and ist seems the firmware is very old and was never updated, photo attached.
Could anybody help with a link to the current firmware?
Thanks in advance,
Diemo
search there:
https://mibsolution.one/#/1/9/MEN2%20-%20LG
MQB_Solution -> men2 - LG
Hello can some one Help me with the right Firmware to update ?
If possible with link in dm´s?
On 19/08/2025 at 09:23, pab567 said:
Sent in PM
Hi, I have a Swing infotainment unit in my Octavia 3 FL with part number 5E0 035 869 D. Recently, CarPlay stopped working for me, so I’m trying to update the firmware in hopes that it will fix the issue.
Could you please check if you have a newer firmware version available for this unit, or share a download link if you do?
Thanks a lot!
Check your PMs. @mikzzz try reset to factory settings, it helps very often.
I want to share my recent experience updating the Skoda Octavia 3 FL Swing unit (LG MEN2), because a lot of details are not clearly documented anywhere, or I did not find that. Hopefully this helps someone avoid problems during FW update.
My unit configuration
Head unit: Swing (MEN2, LG)
HW number: 5E0 035 869 D
Original firmware: MEN2_EU_SKGPx_P7381L / MU 8740
Modules present: MUCPU, MUPIC, MUDAB, BT, SmartLink
Modules NOT presented: MUTNR, ENGECU - This is very important later, because missing modules must be unchecked manually.
Why I updated? After updating my iPhone to iOS 26.1, CarPlay stopped working. A factory reset solved the issue, but I decided to update the firmware to 8755 for stability.
Update procedure
-              Use SD card, FAT32 (USB should also work, but SD is more reliable). Copy the content (not the folder) of the firmware package MEN2_EU_SKGPx_P0080L_8755 to the root of the SD card. Thanks to @pab567 for providing that. You can also download the package here, the *_working one: https://mibsolution.one/#/1/9/MEN2%20-%20LG
- Insert the SD card
- Hold SETUP for ~10 seconds to enter UPDATE MENU.
- Choose UPDATE. The unit automatically selects modules to update → uncheck everything that does NOT exist in your unit (It has an empty number of application version).
In my case, I had to uncheck MUTNR and ENGECU, otherwise update failed.
- Start update.
- Ignition does not need to be ON, but make sure the battery is not weak (keep charger connected if unsure).
What happened during my update. The head unit attempted to update all modules including the ones that are physically missing.
This resulted in:
MUCPU and MUPIC → updated successfully (8740 → 8755)
SmartLink → updated successfully (0072 → 0074)
MUTNR → update attempted even though module is not present → signature error
ENGECU → attempted but does not physically exist → failure
Even though the update ended with “Software update failed”, all real modules were actually updated and the system is working.
Important advice
1. Always uncheck modules you don’t have. If a module shows “empty” as previous version, you must uncheck it before updating. Otherwise you will get errors like: “33 – Source signature cannot be confirmed. System will restart…”
2. Swing MEN2 (LG) does not show all modules correctly in UPDATE MENU and missing modules may appear in the list → just uncheck them.
3. No downgrade possible. Once updated to 8755, you cannot return to 8740 (cryptographic signature prevents it).
Hope this helps future Swing users!
Hello Pab567,
Would you be so kind and send me an update on my device if it's there a chance.
Thank you & Regards,
Peter
Hello Pab567,
Can I have the 8755 non-official upgrade for the following Swing over Fabia 3 ?
Thanks.
Hello,
I'd also like the update for my Skoda Fabia. I'm currently on version 8742 and I'm looking for version 8755. Thanks in advance.
Thanks pab567
Hi, is it possible to get a download of MU 8755 also? Struggling with crackling on my system
@pab567
Hello, I have firmware version
MEN2_EU_SKGPx_P6473L
MU 8170
in Swing radio in Skoda Kodiaq 2017
I also have problems with connecting Android auto by my Samsung Z Flip 6 with usb cable.
Is it possible to update radio to MU 8755 or some other version newer then mine? And could you please send me firmware package? Thank you for your time and best regards )
All check your PMs.
For the future pls make sure to use @ when you want to ping anyone - @pab567 will work but if you miss @ then I don't get notification and unfortunately due to family and health issues I am not able to read all the threads.
Hello @pab567
“I just bought a 2020 Fabia Combi, and unfortunately my Swing radio is crackling when I’m listening to music via Apple CarPlay with a cable. Could you please fix it?”
p.s.
Is there any cordless solution for this radio? i tried bying a usbtransmitter and this was crackling too, when i used carplay?
Kind regards
Emil
link to MEN2_EU_SKGPx_P0080L_8755 sent in PM
Hi @pab567 , I am a new member and cannot send PMs yet. Could you please help me with the SmartLink activation patch for my Delphi unit? Version: MEN2_EU_SKGPx_P7381L MU 8740. Thanks!
@Vladimir2708 I'm sorrry but I don't know the solution to patch your unit.
Could I please get an update for this? I would very much appreciate it. I checked the mibsolutions website rep but i'm kind of lost in it. Thank you in advance.
i'm guessing it's here: https://mibsolution.one/#/1/9/MEN2%20-%20LG
Edited by chillbro
Hello everyone,
I hope you're all doing well.
I own a 2019 Skoda Fabia 1.0 MPI and I am looking for some help regarding the infotainment software on my car. I checked the Skoda Update Portal using my VIN, but unfortunately it reports that there are no updates available.
My infotainment unit details are:
  • Vehicle: Skoda Fabia III (NJ), 2019, 1.0 MPI
  • VIN: TMBEA6NJ4KZ61****
  • Part Number: 6V0 035 869 H
  • Hardware Version: 690
  • Software Version (MU): 8740
  • Train Version: MEN2_EU_SKGPx_P7381L
  • Bluetooth: C190
I have seen discussions mentioning newer firmware versions such as 8755 and possibly newer train versions, so I was wondering if anyone could help me obtain the correct firmware package for my unit or point me in the right direction.
Another issue is that Apple CarPlay has never worked on my car since I bought it. I am not sure whether this is related to the firmware version, SmartLink activation, or something else. If anyone has experienced a similar issue or knows how to get CarPlay working on this specific unit, I would greatly appreciate your advice.
Thank you very much for your time and assistance. Any help, recommendations, firmware links, or guidance would be greatly appreciated.
Best regards,
Fabia owner from Romania
