Skoda Swing Firmware Update - MU 8755
Check your PMs
  • Replies 112
  • Views 21.1k
  • Sent on PM
  • PM
  • General rule I recommend to follow is "If it works without any issues don't touch it" which means don't make a firmware upgrade if everything works ok. Bricking th eunit during firmware upgrade is not
11 minutes ago, pab567 said:
Check your PMs
Thank you so much !!!
On 07/03/2025 at 19:04, pab567 said:
First of all - although I am from POland and Polish is my mother tongue but this is ENglish forum so pls be so kind to use ENglish :)
MirrorLink is obsolete, it has been abandoned by all phone manufacturers, so only Android AUto and Apple CarPlay are in scope. As you have SWING you will need Bolero or Amundsen infotainment reader, infotainment display, new USB and cables to connect it all.
Hi, I need your help with this situation:
I've a SWING radio with SW ver: MEN2_EU_SK_P5040L MU ver: 6490, in this case what are my alternatives?
Buy a used Bolero or Amundsen box and replace the front unit with a compatible one?
Or
Buy an alliexpress multimédia unit and retrofit it?
Thank you in advance.
I do not recommend aftermarket units. To replace with Bolero or AMundsen you need display unit, glove box unit and harness to connect it all. Glove boxunit must be patched to disable component protection and enable new features.
Is it possible for you to send me the download link also? My current software is as follows! Thanks so muchIMG_0011.JPG
Hi @pab567 would you be so kind to share the file as well for my unit?
Check your PMs
Dear pab567,
I am new to the forum and wanted to write you a PM, but I am not allowed to do that as a new user.
Anyway, I am new to the world of infotainment coding and would like to know my options if you would be so kind to get me introduced, as I have seen you are very helpful around this forum. I know that you do not recommend to repair which is not broken, but my infotainment does not even allow me to connect to it with bluetooth (which I consider to be the most basic feature). Also when I hold Setup button on infotainment, I do not see the option "Function Enabling Codes", so I cannot even check which codes are enabled and if some are available for enabling.
My car: Skoda Fabia Mk3
Infotainment type: Swing
Part number: 6V0035867E
Hardware: 050
Software: MEN2_EU_SK_P6340L
MU: 7080
Hi,
Ive a Skoda Fabia 2018 currently running MEN2_EU_SKGPx_P7381L and i can see i need to be running MEN2_EU_SKGPX_P9160L - can you provide the file to load onto my SD card?
On 07/04/2025 at 22:00, pab567 said:
Check your PMs
Hi,
I only have MEN2_EU_SKGPx_P0080L_8755 :(
On 13/04/2025 at 18:51, Pabre said:
Dear pab567,
Hardware: 050
MU: 7080
You have simplifies version of SWING, without DAN and without built-in Bluetooth. If Bluetooth is all you need then you can replace it with full SWING version. New unit must have Component protection removed by Skoda dealer.
If you would also like to have Android Auto or Apple Car Play then you must swap to Bolero or Amundsen but in this case new unit must be patched.
I’m having the same issue. @pab567 please could I have this too?
  • 4 weeks later...
On 19/07/2024 at 16:56, pab567 said:
Envoyé en MP
On 30/03/2025 at 12:46, pab567 said:
Vérifiez vos MP
Can i have a link for updates my MEN2_EU_SKGPX_P7381L :8740 for skoda rapid 2019
i need carplay and gps thanks you:)
I have only MEN2_EU_SKGPx_P0080L_8755
Like many others, I am looking for an update for MU8755, as I am experiencing that version 8740 stutters in carplay. Are there any kind souls who would send it to me?
@pab567
On 10/02/2025 at 13:51, pab567 said:
Pls specyify part number and current SW version
Can you please send me the file also thank you
Software Version: MEN2_EU_SKGPx_p7381l
MU Version Currently: 8740
Check your PMs
Im on 8740 In a fabia Thanks in advance !
Already in PM
Hello! I currently have this version: MEN2_EU_SKGPx_P7381L. Does someone have the update files?
Can you help me too @pab567 ?
Edited by playa
Download link sent in PM
Currently running MEN2_EU_SKGPx_p7381L 8740
Could you send me the update too please.
