barn find felicia pickup.
On 16/11/2026 at 08:46, skomaz said:
Buy a new one... It'll cost you that in your labour time to fix it
Sigh, you're a genius, but I'm so next level I did BOTH
  • Replies 302
  • Views 56.3k
  • Welded up the drilled out spots on the back side drilled out for plug welds First tacks Fire dept violence and alignment grumbly tin Making sure we didn't get it too wrong All other
  • It's been a three day marathon, I'm knackered. I got the starter back on, clutch inspection plate back on, clutch hooked up and the electrics hooked back up. Started it up, chucked it in gear and
  • poked it with the air shears till I realised I couldn't turn a corner with them (maybe this is user error) then did the rest with a worn down, thus smaller and more manoeuvrable angle grinder disk.
That's like trying to fix something but breaking it more then throwing it away and buying a new one anyway (which I have to admit is sometimes my modus operandi too).
I get you, but this is so otherly broken in that it's completely functional now and will be replaced by a slightly probably longer lasting one in a few days. it's POSSIBLY the most useless thing I've ever done since being born. At least TRYING to fix something and failing, then buying something is just accepting loss and moving on. Maybe I'll mount the old fixed gear shifter on the garage wall as a testament to my idocy, but tbh the truck on the drive does that fine....
Recently Browsing 2
