barn find felicia pickup.
Yay, I found out what the thing with 4 pipes in it is, it's the brake bias thing, so when heavy stuff goes in the back a spring presses a piston and puts more braking on the rear. I need to paint mark it before I disconnect it because it's calibrated. That's awesome, one less thing to panic me about dropping the axle. I'm now wondering if it's axle out first or tank out first because I THINK the brake line goes up over the tank. I need to spend more time under there with a big torch.
  • Replies 290
  • Views 55.2k
  • Welded up the drilled out spots on the back side drilled out for plug welds First tacks Fire dept violence and alignment grumbly tin Making sure we didn't get it too wrong All other
  • It's been a three day marathon, I'm knackered. I got the starter back on, clutch inspection plate back on, clutch hooked up and the electrics hooked back up. Started it up, chucked it in gear and
  • poked it with the air shears till I realised I couldn't turn a corner with them (maybe this is user error) then did the rest with a worn down, thus smaller and more manoeuvrable angle grinder disk.
I tried to crack a line at the back but my spanners are too crap, after work I went and picked up a couple of 'correct ones' that wrap further round and just have a slit so you can get them over the brake line.
I took the cap off the master cylinder in prep to let the system drain (the fluid is decades old) and found that someone had popped the level sensor thingy out of the cap so it was actually open to the air all this time, hygroscopically poisoning the fluid. I've managed to pop that back in so it'll be ok for the future when it has fresh juice.
Later on I was watching a bit of old telly and felt a bit seen:
Well, that's torn it.
I think it's the humidity but in the time it took me to get vise grips on the flexy hex and crack that flare my hands were DONE.
But this is cool, now I've done one and the 'fluid' is falling out I feel like I'm just a paint marker, a couple of flare fittings, and 3 bolts away from getting the axle out!
I really need to park this and finish my solar panel frame because all the wood bits are in the middle of my garage and I'm going to break a leg climbing over them.
Normal brake fluid colour? Smells a bit dark.
The whole lot is going to get drained for fresh. It old.
entropy is such an arse, I've been welding on the polo for it's mot.
On 23/03/2025 at 17:24, skoda_cat said:
I got the engine drain out which was a fight, very galled up threads. when the plug CAME out no coolant followed and refused to till a screwdriver went in the hole and came out a horrible colour. Then we got a trickle. so I flushed it every which way till the water ran through.
Hi,
I’m have trouble getting my engine to run at temp and thought I’d tried everything until I read this in your thread. Could I ask where the engine block coolant drain plug is please?
Rob
20 minutes ago, Rsedmonds said:
Hi,
Rob
Yeh, as you face the front of the car, with the bonnet open obviously, the drain is at the right hand side of the block at the bottom of the cooling jacket around the cylinders. It just looks like a bolt, it’s probably easier to SEE from under the car but only if you have the deflector plate removed but if you fumble around under there you’ll find something like a bolt head, because it’s a bolt :p
The channel inside goes in pretty deep, I had a wee rummage inside and a lot of snot eventually came out, followed by all the water I’d put in.
There’s pictures of it somewhere in this thread (page 2, it’s just under the valve cover plate) I recall thinking it was on the bottom of the engine but it’s on the front, the engine leans slightly forwards I think though. Good luck.
For the thread: the polo passed mot, no advisories.
Edited by skoda_cat
I’m not seeing it, what engine is yours on mine is the 1.6 AEE engine?
On 11/08/2024 at 16:58, skoda_cat said:
It's a 1.3MPI petrol,
sadly for you.
Good luck with your explorations.
I had to use this inappropriate hammer to SMACK this lifting cup out of the hole it was rusted into with copious penetrating oil.
But with some light polishing and some lithium grease it spins like a top now, woo.
It won't stop raining so I can't welllldddddddd.
That's not even my jack, it's just on permanent loan. at least I get to restore SOMETHING.
Why did none of you tell me about frogparts? Am I going to get beaten to **** on import duty?
Awwww, they'll post seemingly ANYTHING to me except the gold-dust truck bed floor. I might actually have a go on a driving holiday to the czech republic, hahahahaha.
I've got a load of repair panels paid for which should hopefully ship on weds, should be enough to get an MOT on this rotten mess.
Best bit, they CAN get a bed repair and brand new tailgate protector using https://matkoakubko.com/ which I will be doing as a celebration the same week that the truck gets an MOT. Is this the year it happens?!
Frogparts so far seem INCREDIBLE.
Woohoo, this lot should help hide some crimes and make some repairs look a bit more professional for the MOT man. No doubt it will take me another year to get all this welded in, but it feels like a step towards road legality all the same.
It's kicking my ass. I've got the brake pipe unions apart, that's the easiest bit.
I need to get the fuel tank out to access the axle bolt heads, and to drop the tank the handbrake needs to come out. I've got ONE of the bolts out from the top, but the other is STUUUUCCCKKK, and i believe i need to undo nuts on the bottom of the back pair, but they're fully SLATHERED in thick rubber underseal, sob.
I thought I could get this thing done in a day, but I'm three days in and achieved NOTHING. Hahahahaha.
I did get an impact gun drrrrrrr thing which is super fun, but hells the rains of rust.
  • 4 weeks later...
I've not given up, but I have slowed down, I bet none of you noticed.
But I've jacked it up twice as high and it's WAY easier to get under now, my neighbour also loaned me a wheely sled thing which makes scooting in and out easier.
Hopefully I can actually get in and rebuild some sill in the next few weeks. I'm feeling like I can make some progress again.
It's not raining today, weird.
Dropped the tail gate off because it's trying to blow out on the bottom edge and I don't want that to get worse, also will be WAY easier to repair off the truck. This gets us further away from MOT of course, because now I don't have a rear licence plate.
Got some of the middle structure welded back in, so there's SOME strength in this back end of the sill.
I'm not going to post a picture of what happened to my shoulder and neck, but molten steel is VERY hot and goes quite a long way into your skin, doesn't it? My bacon smells overdone, I think these tracks are going to be in my skin forever. I was wearing full overalls, welding mask, cap, and gloves; but the molten trickles are cleverer than me, I got got. sad face emoji.
not to let that drama get the better of me I've started work on closing panels for the outer sill:
I'll hold off welding that till I've made the one for the other side.
Then it's just plating the inside of the arch and building a return for the end of the sill.
I should be able to get my jack stand under THIS bit then, and repair the larger but simpler section which I can't get at right now because the stand is in the way.
I'm happy to be making a bit of progress again anyway.
  • 3 months later...
Been a minute, sorry. I got some mild confidence and tried to weld that patch in, but the sill is just tissue paper, I can't get any weld on it without it blowing itself to death. I'm going to cut my losses and buy two complete outer sills and go mental with the angle grinder. I do wonder if I need to brace anything first though.
That job being trashed I figured I'd get it off axle stands for a bit. So my neighbour and I started bleeding the brakes, that's when we found out both rear wheel cylinders were seized, yay.
Better than that, the bleeder on the back left just went PING and sheered off. Yay.
The BESTESTS thing was that when we got the first drum off we found the hub nut was LOOSE (face palm emoji) but anyway the mess inside was like:
Only ONE broken spring, heh.
We got it all wrestled off but had to drill out the bolts for the brake cylinder.
That's just crap on the axle thingy, it's not actually knackered.
The process of trying to free the pistons from the second cylinder broke it but also look at the STATE of these things:
Soooo crunchy
We popped to the local motor factors and ordered a cylinder to see if it would match up, and got new shoes and springs, we left the old ones sprung up as references:
In an effort to cheer up, I wired in the second VIBE BLACKAIR T12 sub and fired up the stereo. When it was just one it was ok but a bit borderline, two however has the ability to get slightly uncomfortable which means there's enough bass D it gives me more enthusiasm to keep chucking money into this PIT in the hope I can drive it one year.
Bought a new cylinder from a local motor factor, then tried to buy a matching one from ebay (the factor could only get one) and the ebay lads said 'are you sure? that's not the right one'. and we discovered that my old pistons are 22mm and the one the factor gave me was a 19.5mm for an ABS car. My truck is too old and **** for that kind of disaster preparedness.
The ebay dude VERY kindly gave me the correct part number which has now gone via autodoc (hmm) and evri (eurgh) and hopefully in a few days we'll have working rear brakes again.
No sills ordered yet, I need to wait for payday.
New cylinders arrived and seem to fit right, they're single bolt units where the old units were double bolted. Not sure if I should pop them in the milling machine and ADD another bolt hole or trust that one bolt with threadlock is enough to hold them in. VW evidently think it's enough, lol.
It's impossible to get an unmodified union wrench on the flexy joint inside the torsion axle thingy. Either the axle is in the way, or you get hung up on the fuel tank. So the flexies had to come out, but that's probably for the best since they're in SOME state and we're going shopping tomorrow morning to see if we can replace them.
Took some fire and stuff to get that to let go. I really need to get my vice mounted properly again.
Happily I have an 'in' with the local garage and we managed to sneak in and have a go on this...
So we have two fresh lines ready to go on if we can fangle the bends ok.
Wish me luck, maybe functioning rear brakes tomorrow... the fronts will surely need the same care and attention. I just want to be able to drive it up and down the drive again for a bit to take the depression about the welding away. I need another payday and then it's new sills and a leather welding jacket so I can stop setting myself on fire.
All rubbed down and some prophylactics added :p
splish
splash
And then we find that the new spring kit for the new brakes isn't right. YAY.
ooh, I found out it's the 50kW version, so the fastest piece of **** low powered crap of the 1.3L options :P lol.
I MAY turbo it one day to make sure the plastic engine breaks, but it briefly does 100bhp :P
The bloody drama
continues apace
but I'm too weak to get the springs in any of the right places, hahaha. Will deffo get these brakes back on in the end. This is improving stuff, it is. I read back through this thread and it's picked me up a bit, this truck has been on a long journey but it's all moving in the right direction.
hmm some progress perhaps, not finalised, it needs the bits and bobs greasing, but i THINK those springs are all in the right places more or less.
these things had BETTER work. This side was MUCH harder, left hand being weaker i needed help from my lovely neighbour to get the brake lever back on the cable, everything else went reasonably well.
I don't look forward to EVER doing this job again, lol.
