Car failing to charge via AC but will charge fine on DC.
So off the back of the software update and/or having to get a new charging flap fitted my car is now refusing to charge via AC at home. DC charging is working perfectly ( two fast charges since I got the car back from Skoda) however I don't want to be doing that on a regular basis. I was able to get the car to take a small charge from home last night, having read about pulling out fuse 3 under the bonnet for a reset. When I checked this morning the setting was on to reduce AC charging so it only charged at 1.9kw.
Thinking that the fuse trick might have fixed it I was dismayed to see the same error I saw yesterday pop up on the dash again this morning - "Unable to fully charge - Consult the Manual". Wishing I had removed the charge cable prior to checking however I don't think that would have made any difference.  Cant be pulling the fuse everytime I want to charge from home so my question is, I assume I will need to return back to the dealer to get this looked at?
Seen this?
Hi - just read through that thread and commented - sounds like its a very similar issue. Whilst pulling the fuse under bonnet did initially work, the fact that the car errored again this morning suggests it needs to be looked at by the dealer again.
