Ice to Enyaq iv
On 24/11/2025 at 10:16, Stonekeeper said:
Mine did that last winter, had to use the hairdryer and multiple lock/unlock (use the button on the dashboard to protect your fob battery) and it opened. Then no problems until August when on the motorway stopped to charge and it wouldn't open lock/unlock worked. This time the solenoid had now failed.
I have re-posted in "moments of joy" about the result.
Phoned Skoda assist they came next day (Fri) opened the flap by snapping the pin, ordered the parts (two parts needed to return to undamaged). Came back Saturday and fitted in less than an hour.
preventive maintenanceis key, spray the mechanism every month with silicon lubricant. Touch wood is worked for me so far
  • Replies 51
  • Views 9.5k
  • Luckypants
    Luckypants
    I have found over the past 3 summers that air-con cooling uses far less power than heating the cabin. It is rare to see power use for aircon above 0.7kW for sustained periods and normally less than 0.
  • First month stats from the car   358mile @ 3.1m/kwh = 115 kw? x 24p = £27.60   although my meter readings suggest we have only used 72kw more than this period last year = £17.28
  • Second month stats from the car   224mile @ 2.7m/kwh = 82.96 kw? x 25.01p = £20.74   although my meter readings suggest we have  used 73kw more than this period last year = £18.26
I did do that which works fine stopping it freezing up, but it didn't stop the switch mechanism failing and needing replacement. Luckily it was still within warranty and i got the opportunity to watch the repair procedure on my drive. So next time I can do it myself.
