Car won't start no errors
Hello all,
Wondering if this has happened to anyone before? Entered car after work, press the Start Button, ignition comes on, nothing. It doesn't even try to turn over, there are no warnings on the dash or infotainment screen under Car. I've tried locking the car and opening it manually placing the key in the centre console, nothing. Left it for it an hour, same.
I'm stumped, any ideas appreciated!
Has the 12 volt battery become discharged?
I've not tested with a volt meter or anything, but the car is driven every day and there's been no battery warnings. All electrics power up no problems as they normally would, it doesn't even attempt to start.
Maybe related to electronic parking brake but I'm just guessing. Maybe check fuses ,assume all other electrics appear working lights,info screen etc.
I did check the break was working, all ok there, rolled back a little and put it back on no problems. It's really weird, I'm thinking about getting jump leads but really don't think it'll make a difference...
Manual?
It might be the clutch pedal switch, does it still show the message about depress clutch to start?
1 minute ago, vfr said:
Manual?
 Good point, I meant to mention this, theres no mention to press the clutch pedal to start. Obviously pressing the clutch does nothing too, is this a common thing, can I visibly check?
Sorry folks, would be helpful if I posted details on the car.
2021 plate first edition 1.0 TSI Manual, had it for 2 and half years, had all the usual blips but this is the first time this has happened.
Hi all, car still at work, checked the under the clutch for anything obvious but all looks good.
Here's a video I recorded of what happens, looks how there's no message to press the clutch...
https://youtu.be/mIobtoCIsBA?si=rOtAmAQ-Lz2_trsB
On SWMBOs Fabia (keyless start) the 'press clutch' message only displays if you press start button without disengaging clutch - what happens it you do that? I'm suspecting a faulty start button.
If you press the start button without pressing the clutch nothing happens, press it again and the ignition goes off.
It's really poor whatever it is, old cars were so much better! 😂
Edited by johnmcb
I suggest getting the start button scanned for correct function of starter function.
Have you been able to confirm that your car battery is sufficiently charged, I haven't had a low battery in mine, but it's conceivable that it won't try at all rather than crank slowly?
Thanks all for your input - Mobile Mechanic came out and initially said it needed a new started/rebuilt. Before deciding to take it away he plugged in his diagnostic tool and clear all historical errors, then it started. I mean c'mon!! £80.
Hope that helps someone in the future.
Symptom: Car doesn't even attempt to start (turn over), no errors on dash etc
Resolution: Connect diagnostic tool and clear any errors. Car starts
Pleased to hear you got it sorted.Thanks for updating.
